Author Topic: Engine ID Number  (Read 1700 times)
Offline Plum_Crazy
Engine ID Number
« on: August 20, 2002 - 08:30:54 PM »
Hi Guy's, trying to verify that the numbers match. Here is the question: the only number I can find on the motor is 2468130. This was on the left side of the block just above the oil pan. The motor is a 383  in a 70 Challenger. Is this the ID number or what? Thanks for the help. Plum_Crazy
Re:Engine ID Number
« Reply #1 on: August 21, 2002 - 05:06:32 AM »
 That is the block casting # the serial # should be above the pan rail behind the mount on the right side & stamped into the block on a 1/2" tall pad
