Author Topic: Where to find connector ?  (Read 3678 times)
Offline tomsa
    • My cars in swedish
« on: August 01, 2015 - 06:39:26 PM »
Hi
Where can I buy the connector sockets (correct term?? ) for the wire harness to ignition and turnsignal switches ?
I mean on the car side.
I have no wiring left in the car and would like to use the connectors on the switches and not cutting them if possible
Offline tomsa
Re: Where to find connector ?
« Reply #1 on: August 05, 2015 - 05:17:19 PM »
No ideas ?
Offline roadman5312
« Reply #2 on: August 05, 2015 - 05:28:10 PM »
Picture of what you need ?    Connectors from steering column ?  Little more info please.
        :rebel:
Offline tomsa
« Reply #3 on: August 05, 2015 - 05:41:08 PM »
        :rebel:
Quote
those who sits in the harness in the car,the other one are attached when you buy a new ignition switch and turns signal switch
Offline tomsa
« Reply #4 on: August 05, 2015 - 05:45:38 PM »
the connector that should be attached at the red arrow
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #5 on: August 05, 2015 - 06:00:05 PM »
might be hard to find but I have seen some later 70 model vans with a plug that may work like on some 78 maybe up to 85 as this one on ebay http://www.ebay.com/itm/Dodge-Truck-Van-1972-85-New-Turn-Signal-Switch-TS111-/361348876767?hash=item54221249df&vxp=mtr  shows one but I am not positive , you would need to find one for a comparison ,,this one is on ebay http://www.ebay.com/itm/1970-71-72-73-74-NOS-MoPar-T-S-SWITCH-Cuda-Dart-Charger-Road-Runner-Challenger-/110293812740?hash=item19ae060604&vxp=mtr  but pricey . this one is for a dodge charger http://www.ebay.com/itm/Mopar-71-72-73-74-Charger-Turn-Signal-Switch-NEW-/400922137169?hash=item5d58d25251&vxp=mtr  but I am unsure about fit ,,
According to jegs Mopar Performance#312-04293102
Turn Signal Switch Assembly
1970-76 A-Body/B-Body/E-Body this will work http://www.jegs.com/i/Mopar+Performance/312/04293102/10002/-1?CAWELAID=1710733951&CAGPSPN=pla&catargetid=230006180000850347&cadevice=c&gclid=CISt34j4kscCFQeBaQodJnYIcg
I havent seen just the plug your looking for
Did find this one cheap for an a-body dart http://www.ebay.com/itm/Turn-Signal-Switch-without-Tilt-Column-for-73-79-Dodge-Plymouth-Chrysler-/231575326647?fits=Model%3ADart&hash=item35eaf70fb7&vxp=mtr
« Last Edit: August 05, 2015 - 06:12:28 PM by 72rtchallenger »
72rtchallenger
what happens in the garage
stays in the garage
Offline tomsa
« Reply #6 on: August 05, 2015 - 06:47:50 PM »
To find the turn signal switch and the ignition switch is not a problem
I looking for the connectors that are in the wire harness that these 2 connects to .
Must be me english that's so bad that I can't explain this :-(
Offline roadman5312
« Reply #7 on: August 05, 2015 - 06:51:17 PM »
              Called pigtails. Don't know anybody that makes them. Would have to be cut off and old harness.
Offline Got JOB
  • Member since 2-14-06
« Reply #8 on: August 05, 2015 - 06:54:07 PM »
Do you want just the white connector with the wires cut off?
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline tomsa
« Reply #9 on: August 05, 2015 - 06:57:01 PM »
Ok
Easier to cut of the one on switch side and buy some weather proof connector or something like that
They are often small
Thanks
Offline tomsa
« Reply #10 on: August 05, 2015 - 06:59:58 PM »
Was looking for the connectors at the car side of the wire harness but I guess it's easier to change both sides to an other type of connectors
Offline Got JOB
« Reply #11 on: August 05, 2015 - 07:03:53 PM »
I think I have an old harness, I will look and see. If I do I can send it to you or just cut the wires off and send the plug.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline tomsa
« Reply #12 on: August 05, 2015 - 07:08:35 PM »
:thumbsup:
A small problem that I live in Sweden maybe
« Last Edit: August 05, 2015 - 07:11:09 PM by tomsa »
Offline Got JOB
« Reply #13 on: August 05, 2015 - 07:56:27 PM »
I have an ignition switch with an 8 wire connector. Its yours if you want it. Give me a postal code and I can see about mailing.
Ricky
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline tomsa
« Reply #14 on: August 06, 2015 - 01:42:35 AM »
Ricky
Don't need the connector on the switch side
