Author Topic: adjusting the clock?  (Read 1120 times)
Offline JoeGrapes
« on: August 02, 2015 - 07:58:58 PM »
Is their a way to adjust the clock? It's running way fast.
Re: adjusting the clock?
« Reply #1 on: August 02, 2015 - 10:27:36 PM »
Yes , depress the button & rotate it back this not only adjusts the time but also the speed .
Offline JoeGrapes
« Reply #2 on: August 02, 2015 - 11:37:01 PM »
Are you saying to adjust the speed all i need to do is push the knob in and turn counter clockwise to slow the clock or clockwise to speed it up?   :2thumbs: Anyway, I think I found the lever to adjust the speed.  I'll just need to make small movments on the lever and let it run until the time stays right.
Offline ToxicWolf
« Reply #3 on: August 03, 2015 - 06:05:35 AM »
That's the way it was designed to work. Any time you make an adjustment of the time, it adjust the speed in that direction,  faster or slower.  :2thumbs:
Offline JoeGrapes
« Reply #4 on: August 03, 2015 - 08:31:19 AM »
Hmmm, so all I have to do if running fast is just keep adjusting the time back until eventually it will keep correct time. Ok I'll try it.
« Reply #5 on: August 03, 2015 - 10:43:47 AM »
 :2thumbs:
