Author Topic: Idler Arm Seal ?  (Read 545 times)
Offline Vodoo Child
Idler Arm Seal ?
« on: August 02, 2015 - 09:20:18 PM »
When I popped off the drag link to change out my oil pan I cut the felt seal between the drag link and the idler arm separating them. The arm is fine so does any body have a part# for the seal or a suitable replacement. Thanks :2thumbs:
Re: Idler Arm Seal ?
« Reply #1 on: August 02, 2015 - 10:06:51 PM »
if it is a bell shaped boot there are poly boots available , check Ebay  , some I have seen just use a thick foam seal not hard to cut out of a piece of foam
