Author Topic: 70 to 74 interior door panels  (Read 2062 times)
Offline mikeporp
« on: August 03, 2015 - 12:31:47 PM »
who makes the best 70 Challenger interior door panels. I need a set of white ones for my 70 challenger convertible with power windows. Thanks.. Mike
Offline 67vertman
  • Member since 9-23-2005
Re: 70 to 74 interior door panels
« Reply #1 on: August 03, 2015 - 01:02:26 PM »
Metro is the only one remaking door panels.  You can order them from Dave at Roseville Mopars, he is a sponsor at gives discounts to CC.Com Members.  :2thumbs:
« Reply #2 on: August 03, 2015 - 01:05:19 PM »
I'm not familiar with where the power window switches are located on the door panel.  I know the standard crank opening holes come predrilled on the Metro panels.  They are the best but might not work for you because of that.  Metro doesn't make the convertible rear panels and the Palco brand panels are junk.
Offline blown motor
« Reply #3 on: August 03, 2015 - 03:57:33 PM »
I got Metro panels from Dave in the winter. They are NOT predrilled for the window crank but the hole location is marked on the back of the panel. The location for the power window hole is also marked. They look awesome  :grinyes:
« Reply #4 on: August 03, 2015 - 04:34:17 PM »
Good to know.  I wonder if that is something Dave had changed.  When they originally came from Metro, the holes were drilled.
Offline mikeporp
« Reply #5 on: August 03, 2015 - 08:18:03 PM »
Ok. Thanks for the info. I know someone selling an older black pair from year one.does anyone know the quality of them. Thanks
Offline anlauto
« Reply #6 on: August 03, 2015 - 08:43:13 PM »
GARBAGE :bricks1:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #7 on: August 03, 2015 - 09:38:07 PM »
challenger crank hole vs switch hole locations are in different areas. noted on the back of the panels. the cuda on the other had are in the same locate which is the reason for the crank hole being made.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline mikeporp
« Reply #8 on: August 04, 2015 - 07:35:32 AM »
Thanks anlauto for the tip on the year one panels. And thanks Dave. I sent you a pm.
Offline JayBee
« Reply #9 on: August 04, 2015 - 08:18:43 AM »
GARBAGE :bricks1:
Unfortunately us convertible owners have little choice when it comes to the rear interior panels.
John
1970 Barracuda convertible
2014 Toyota Avalon
