Author Topic: Dumb Electrical Question.....  (Read 4397 times)
Offline anlauto
« on: August 03, 2015 - 04:17:07 PM »
I'm restoring a Cuda with a aftermarket (Day Two type ) type gauge cluster mounted under the dash.
My question is regarding the "VOLT" gauge....It has two studs on the back, I'm assuming pos & neg, but can I just run jumper wires from the factory "AMP" gauge ?
If not, where would I get the two wires to run to the "VOLT" gauge ?
Offline edl94
  • She Cuda
Re: Dumb Electrical Question.....
« Reply #1 on: August 03, 2015 - 04:35:56 PM »
 Amp wires are hot all of the time. You need power from a switched source after the ignition switch.
Offline roadman5312
« Reply #2 on: August 03, 2015 - 04:38:08 PM »
         power in, ground out.
Offline dougs bs23
« Reply #3 on: August 03, 2015 - 04:42:35 PM »
just installed a volt gauge, one terminal was marked ground and pos terminal connected to a "switched" connection that only activated with the key in the "on" position so as to not put a constant draw on the battery
Offline anlauto
« Reply #4 on: August 03, 2015 - 04:57:06 PM »
Sound can I ground it to the dash frame, then run a positive wire to the accessory terminal on the bottom of the fuse box ?
Offline roadman5312
« Reply #5 on: August 03, 2015 - 05:06:00 PM »
                       Yep, sure can. Then take the ammeter wires and crimp them together.  :2thumbs:
        :rebel:
Offline anlauto
« Reply #6 on: August 03, 2015 - 06:12:20 PM »
Can I still run the factory AMP meter ? I hate the look of "dead" gauges in the dash...
Offline roadman5312
« Reply #7 on: August 03, 2015 - 06:17:59 PM »
                           If ya want to, but best to bypass it  :2cents:
« Reply #8 on: August 03, 2015 - 06:42:54 PM »
No, unless you want to read the voltage drop across the amp gauge.
It would be cleaner to use the yellow molded (pretty sure yellow is the acc one) connector up behind the gauge cluster. When you use the acc feed off the fuse box, the wire is noticeable when you get into the car.  :2cents:
Offline anlauto
« Reply #9 on: August 03, 2015 - 06:51:38 PM »
No, unless you want to read the voltage drop across the amp gauge.It would be cleaner to use the yellow molded (pretty sure yellow is the acc one) connector up behind the gauge cluster. When you use the acc feed off the fuse box, the wire is noticeable when you get into the car.  :2cents:
That's a good idea...So I can just pick up power anywhere that has power with the key in the "run" position and no power with the key in the off position  ...correct ?
Also thinking of running the ground wire to a common area on the door post behind the kick panel. The new radio as well as the power antenna also need a good ground.
« Reply #10 on: August 03, 2015 - 06:55:00 PM »
Correct.
Personally I run a ground wire from the body to the dash frame just to ensure good gauge grounding. Running your grounds to the body is equivalent.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: August 03, 2015 - 07:24:55 PM »
Good idea, from the top right of this schematic:
www.mymopar.com/downloads/1970/70BarracudaA.JPG
Good thing I'm not using the A/C anymore as I have more ports open.
 :woohoo:
Offline dougs bs23
« Reply #12 on: August 14, 2015 - 01:55:18 PM »
So, would it be advisable to add a fuse into the new meter ? If so what size? or just run  it as a direct connection?
Offline anlauto
« Reply #13 on: August 14, 2015 - 05:51:24 PM »
Good question, thank you  :dunno:
Offline JoeGrapes
« Reply #14 on: August 14, 2015 - 10:25:00 PM »
I use both the stock amp gauge and an after market volt gauge. I plug the volt gauge into one of the accessory feed plugs in the dash wiring harness. There are two of them each with a tan wire and they already have a dedicated 20 amp fuse in the fuse block. Seems to work well.
