Author Topic: So... Drum Brakes.  (Read 1453 times)
Offline RCCDrew
So... Drum Brakes.
« on: August 04, 2015 - 12:25:29 AM »
I'm trying to get a Charger on the road that has been off the road for quite a while. Long story short, I replaced the master and all the wheel cylinders, a front brake hose and a front drum, and adjusted the front shoes. It still seems like the rear is locking up before the front.  I haven't driven a drum brake car in a while. Is this normal? Maybe I need more front brake bleeding? Suggestions?
Offline 1 Wild R/T
Re: So... Drum Brakes.
« Reply #1 on: August 04, 2015 - 01:58:03 AM »
Or tighten the adjustment up front and/or loosen the rear adjustment.. Just know under hard use they will fade badly... Back in the 70's I owned a few muscle cars with drum brakes, they work OK, till about 75 mph at which point it's like someone flipped a switch... Useless... Drove a can with discs & after that if I bought a car with drums the first change was always discs...
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: August 04, 2015 - 09:57:19 AM »
 :iagree:  Adjust them with a spoon or flat head screw driver.
Offline RCCDrew
« Reply #3 on: August 04, 2015 - 11:59:04 AM »
Yeah, I'm planning a front disc swap. Just trying to get it decently safe right now.
Offline dfrazz
« Reply #4 on: August 04, 2015 - 02:33:29 PM »
Exactly what I did with my Charger, then the drums failed because a spring popped.  I called Dr Diff and had front discs on within a week.  Don't take chances.
Offline Racer57
« Reply #5 on: August 04, 2015 - 05:18:08 PM »
Just out of curiosity.............. Is there a rear disk conversion available ?
« Reply #6 on: August 04, 2015 - 05:28:05 PM »
Yep!  :wave: I have the 10.7 kit on mine. Works great no issues.  Works with the stock tapered bearings too.  :2thumbs:
http://www.doctordiff.com/brakes/rear/
Offline dfrazz
« Reply #7 on: August 04, 2015 - 05:38:11 PM »
I would recommend these two, although I put the Right Stuff kit on my Challenger that required green bearings. Cass is great to work with.
