Author Topic: window regulator replacement  (Read 2644 times)
Offline gafletch
« on: August 06, 2015 - 05:08:50 PM »
 Is there a manual page on replacing a '70 Cuda window regulator? I'm trying to figure it out.
Offline 73_Cuda_4_Me
Re: window regulator replacement
« Reply #1 on: August 06, 2015 - 07:35:09 PM »
My 73's regulator is covered in the body service manual, Section 6 - Side Glass
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline gafletch
« Reply #2 on: August 06, 2015 - 11:17:54 PM »
Anyone have a CD available?
 My window was stuck in the up position. Trying to get it out so there's more room to remove the regulator.
Also, where can I find the fuzzy pads that press against the glass?
« Last Edit: August 06, 2015 - 11:22:51 PM by gafletch »
Offline gafletch
« Reply #3 on: August 10, 2015 - 07:00:30 PM »
According to AMD, only the '70 regulator will work on the '70 Barracuda. The used one I bought has a smaller crescent gear. Has anyone tried a 71-74 in a 70 Barracuda?
Offline loco340cuda
« Reply #4 on: August 10, 2015 - 09:08:59 PM »
I have and there are no issues.  The 70 does not look exactly the same as the 71-74, the 70 has more teeth but it does not use them all.  When I first put in the 71-74 reg in my 70 Cuda the window got hung up while I was rolling it up or down (I forget) and I thought I was screwed because I did not use a 70 style regulator.  It turned out it was just hanging up because the window guides had not been oiled yet.  There should be no issue except for appearance.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline gafletch
« Reply #5 on: August 10, 2015 - 10:29:43 PM »
Thanks. I guess I'll try it and see.
Offline mopardave
  • Sponsor
    • rosevillemoparts
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline gafletch
« Reply #7 on: August 12, 2015 - 11:21:16 AM »
Ok guys, I have all the parts out. What steps to put it back together?
Offline Racer57
« Last Edit: August 17, 2015 - 11:06:04 PM by Racer57 »
Offline solarguy
