Author Topic: Smashed my long tubes on a steep driveway  (Read 8787 times)
Offline marcus
Re: Smashed my long tubes on a steep driveway
« Reply #15 on: August 11, 2015 - 12:07:18 AM »
Stage 3 firm feel should arrive this Friday.  :)
I'm probably going to need to remove the drivers side header. Can I reuse the gasket? Never started with it on. Not sure if that matters. If I do need a new gasket any suggestions on brand? I was considering getting this set.
Offline FCC
  • 1973 Dodge Challenger 340
« Reply #16 on: August 11, 2015 - 12:27:47 AM »
Sorry for he smashes long rubes but very nice write up and detailed! I too went with FFI stage III gearbox and I'm using the coupler retainer.   It slipped on with little prying and holds the top cover on securely.
« Reply #17 on: August 11, 2015 - 11:45:36 PM »
should be able to reuse the gasket .
 Copper gaskets seem to work very well if they fit properly
Offline marcus
« Reply #18 on: August 15, 2015 - 01:30:28 AM »
Firm Feel Stage 3 has arrived!  :bananasmi
More to come tomorrow...
Offline marcus
« Reply #19 on: August 16, 2015 - 06:38:38 PM »
Firm feel stage III requires using your old Pitman arm. Removing bolt was the most challenging
I put the gear in a vise and turned the pitman arm counterclock wise until it hit the steering stop. Sprayed the bolt with a lot of PB removal and then beat on the end of the crescent wrench like a mad man. Took about 5 minutes of alternating between spraying PB and beating the end of the crescent wrench with a hammer.
Once the pitman bolt came off, the arm went easy using a pitman arm puller.
Having the right tools sure makes things easy!
Firm Feel Stage III requires using the old return valve and high pressure fitting. New o-rings and brass washer is provided.
New o-rings in place. They are orange, old rings are black.
New brash washer on the high pressure fitting.
Installed the valves and high pressure on the new stage III. Turned the stage III Pitman arm shaft counter clockwise till it hit the stop so it would be the the same position as the old steering gear, then installed the pitman arm in the same position.
Removed the motor mount bolts and starter then jacked up the engine about 2 inches.
Removed the headers. They came off clean. All gasket sealer stayed on the gasket. The headers were clean with no gasket sealer stuck on them.
After the headers were off the Firm Feel stage III went right in with no problems. 3 bolts later -
Put a thin coat of gasket sealer directly on the header flange and bolted it back in. Reconnected the motor mount bolts, pitman arm to steering linkage, power steering hoses, steering column assembly and reinstalled the starter. Refilled coolant, power steering and oil.  Total time spent was about 4 hours.
The old exhaust pipe flanges do not line up with the new headers. I need to cut them shorter and have the new flanges welded on. Since I do not have a welder nor do I know how to weld I took the exhaust pipes and Challenger over to my favorite muffler shop to do the work.
Needless to say, it was one LOUD drive!!  :biggrin:
The Firm feel stage III is much tighter than stock. My first impression was that it feels very similar to my Magnum SRT8. Will have a better idea as I drive it more, but I really do like the way it feels thus far!
« Last Edit: August 16, 2015 - 06:50:45 PM by marcus »
« Reply #20 on: August 16, 2015 - 08:12:40 PM »
 :2thumbs:
Looking good
« Reply #21 on: August 17, 2015 - 07:30:54 AM »
Nice!  :clapping: :2thumbs:  Small block header installs are so much nicer than BB!  :grinyes:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #22 on: August 17, 2015 - 10:01:09 AM »
 :rebel:Sweet! Thanks for the details as I am about to embark on this adventure this Fall.   :cooldancing:
Offline marcus
« Reply #23 on: August 25, 2015 - 10:57:56 PM »
Forgot to post before and after photos between the old headers and new. These new ones should have a much lower chance of getting smashed.
OLD
NEW
Offline dfrazz
« Reply #24 on: August 26, 2015 - 08:02:01 AM »
Have you had a chance to drive it anymore to get a better feel of the Stage III?
Offline marcus
« Reply #25 on: August 30, 2015 - 10:17:29 PM »
Just drove it over the hill to Santa Cruz. The Stage III is definitely heaver than my SRT8.  Overall it feels much better than the stock box. When at speed you can feel the road much more. It feels almost like a manual steering box. Parking takes more work. I do have a smaller aftermarket steering wheel which does make it harder to steer than the larger stock steering wheel.
