Author Topic: 1970 Challenger SE  (Read 66212 times)
Offline BAM
  • www.FindCyprus.org
Re: 1970 Challenger SE
« Reply #210 on: March 22, 2017 - 03:58:20 PM »
Thanks for the photos. Very helpful. The 2nd layer of the upper cowl on my car has rotten corners so i will have to patch it anyway. Ahhh...so much work/fun coming up this days :))
Offline Challenger in NC
« Reply #211 on: March 22, 2017 - 04:36:58 PM »
:2thumbs: Keep posting your photos and progress.
Offline BAM
« Reply #212 on: March 23, 2017 - 09:28:05 AM »
Hey guys. Can someone tell me if the 0.5cm gap is ok for the rear window plug? I mean between the plug and the roof and between the plug and the trunk thing
Offline 1 Wild R/T
« Reply #213 on: March 23, 2017 - 12:06:11 PM »
Normal... On an OE install they used a 50mm x 50mm square of aluminum foil tape like is used in the A/C trade over each screw location & the vinyl top hid everything else...  Honestly if it were mine I might tape the whole seam since the tape is out & in hand anyway...
« Last Edit: March 23, 2017 - 12:07:47 PM by 1 Wild R/T »
Offline BAM
« Reply #214 on: March 23, 2017 - 12:52:03 PM »
here it comes:
photo 1: is it normal that this A pillar to have the upper edge pointing towards the exterior of the car? it looks to me that it should be bent inside and enter the roof frame as the passenger side does. Can someone please confirm before i start hammering it? :)
photo 2: this is the point that i went ahead and gave it 2 spots of weld...
last photo: i`ve put the rear window in place and aligned it with the help of the factory holes and i have an even gap of 5mm all around;
 overall, i didn't do much today but this is my progress so far
« Reply #215 on: March 23, 2017 - 07:27:45 PM »
Here you can see that the top portion of the A-pillar tucks behind the roof structure.
« Reply #216 on: March 23, 2017 - 07:30:32 PM »
Here's what my replacement piece looked like before I trimmed it.
Offline BAM
« Reply #217 on: March 24, 2017 - 03:14:37 AM »
Yes, on that side the new pillar is bent in. On the driver side is not...
Offline BAM
« Reply #218 on: March 30, 2017 - 06:53:57 AM »
can someone please tell me what would be a correct gap between the windshield and the a pillars and also between the windshield and the upper brace and the cowl.
Offline BAM
« Reply #219 on: April 05, 2017 - 04:07:29 AM »
1st time welding something and it looks pretty bad :)
I'm sure that a bit of grinding will make it look good
« Reply #220 on: April 05, 2017 - 06:45:13 PM »
Doesnt look bad, it will clean up after grinding and youll get better as you go along.
« Reply #221 on: April 05, 2017 - 06:51:44 PM »
Its great your car still has all the chrome molding around the doors and hood.
Offline BAM
1970 Challenger SE
« Reply #222 on: April 27, 2017 - 07:16:34 AM »
Not having much time this day but this is how the challenger looks in this moment
Offline YellowThumper
  • I left the snow for this?
« Reply #223 on: July 18, 2017 - 01:43:01 AM »
Anything new to update on this?
Curious about how you are sorting thru it.
Offline BAM
« Reply #224 on: July 18, 2017 - 03:38:00 AM »
nothing major done on it lately as i don`t have the time.I need to order a complete floor and firewall before i continue.
The roof frame is welded in, everything fits perfectly (side windows, windshield, rear window and roof). Will start posting again as soon as i find the time to pass by the garage.
