Author Topic: 1970 Challenger SE  (Read 66211 times)
Offline redo1973
Re: 1970 Challenger SE
« Reply #225 on: July 18, 2017 - 06:29:33 PM »
Wow, what a nice job on this build. :2thumbs: :popcorn:
Offline YellowThumper
  • I left the snow for this?
« Reply #226 on: July 19, 2017 - 12:37:43 AM »
Thank you
Offline BAM
  • www.FindCyprus.org
« Reply #227 on: August 01, 2017 - 11:38:57 AM »
hahaha. sorry guys, i don`t have much time to post here. Still, there is nothing new with the car.
will post photos as soon as i do something on it :)
Offline BAM
« Reply #228 on: August 30, 2017 - 12:05:24 PM »
I`m planing for the weekend to finish welding in place the A pillars and maybe finish putting in place the roof braces. Maybe October will bring me the complete floor and quarter panels (hopefully also the lower firewall)
anyway, i will try to remember to take some photos with the work
« Reply #229 on: September 02, 2017 - 08:00:03 PM »
Thanks for the update
Good luck with the progress.
Offline dakota
« Reply #230 on: September 02, 2017 - 10:12:44 PM »
You are working though challenges that would make many other give up, especially on getting parts.  Keep going!
Offline Beekeeper
« Reply #231 on: September 02, 2017 - 11:43:13 PM »
Nice thread. I just finished reading it from start to finish. I know who much work this is as I'm doing a large job myself on my 70 Challenger. Thankfully mine does not have roof issues but everything else on my car was rusty so I've been slowly cutting and welding in new.
On your welding...I too had never used a welder until my project started. Not sure what your using but I went with a mig type with gas rather than flux core. I use small .025 wire rather than thicker stuff for better control on thin metal. I also bought a welder which automatically feeds the wire at the correct speed so I don't have to fight with it. The result? In the first 10 hours of welding, it was good but welds were not pretty and I spent a lot of time grinding. After that, I found myself getting better and better. Make sure you have a good auto darkening helmet, use bright lighting on your work to help see what you're doing, I keep the shade on my helmet around 9 so I can still see the work well. If you find the arc blowing through your work, then you are welding in very thin pitted rusted out metal or you have too much heat (current). Make sure you also weld in small increments or the heat will warp it bad.
On your rear quarters...have you inspected them well to ensure the rest of them are useable? They typically rust out down low and god only knows how much filler has been put into them given what they did to the rest of the car.
If you are certain that the only part of the quarters you need is the upper triangle at the roof, private message me and I will check mine to donate for your project. I am currently doing the metal work on the back half of my car and I plan to buy new quarters. My old quarters have rust down low but the triangle areas of mine might be useable for you. Can't promise much until I remove them but if the are good, I will take care in removing them and you can have them.
Offline BAM
« Reply #232 on: October 01, 2017 - 04:58:41 AM »
that`s a useful reply Beekeeper. I also decided to change the quarters completely as i want to change the trunk floor and extensions also. I will order everything i need together so i can drop the shipping price but this will take time.
Meanwhile, I`m starting to order stuff for the engine to get it running. For the moment, I`m stuck on what exactly repair kit i need for this carburetor. If anyone can help with a link, this are the numbers found on it:
Offline 73440
« Reply #233 on: October 01, 2017 - 08:45:01 AM »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline BAM
« Reply #234 on: October 01, 2017 - 08:45:55 AM »
http://www.carburetor-parts.com/Holley-2280-Technical_ep_335.html
Would that carb be a Holley 2280 ?
No idea... is there another number i can see in order to identify?
Offline DAYLEY/CHALLENGER
« Reply #235 on: October 01, 2017 - 08:53:19 AM »
Does that say Made in Japan ????
Dave or David
Offline 73440
« Reply #236 on: October 01, 2017 - 08:55:18 AM »
https://quadrajetparts.com/holley-2280-carburetor-rebuild-kit-4082f-chrysler-1975-dodge-1962-plymouth-1962-p-1540.html
I have bought a lot of parts from this company , quadrajet ,
Look at the parts included and see if things match.
http://www.carburetorfactory.com/expvw16.html
Exploded view of Holley 2280
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 73440
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline BAM
« Reply #238 on: October 01, 2017 - 09:03:47 AM »
« Last Edit: October 01, 2017 - 09:13:48 AM by BAM »
Offline BAM
« Reply #239 on: October 01, 2017 - 11:39:26 AM »
Anyone recognizes this carburetor? :) I`m thinking to just order a new one if i don`t find a set of gaskets
