Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Column lock release - sometimes car wont start
« previous
next »
Print
Pages: [
1
Author
Topic: Column lock release - sometimes car wont start (Read 1087 times)
AmazenToys
Jr. Member
on:
August 10, 2015 - 12:03:06 PM »
1973 Challenger, sometimes when I turn the key there is nothing, if I move the column lock key release back and forth it will then start.
What is this a sign of ? what needs to be replaced ?
Logged
1973 Dodge Challenger, Warren Michigan.
HP_Cuda
Hit the skinny little pedal on the right!
Sr. Resident
Mopar or No Car!
Re: Column lock release - sometimes car wont start
Reply #1 on:
August 10, 2015 - 12:50:36 PM »
When you say you turn the key, does it go to the ACC position and then to the start position?
With the column lock in place you cannot move it far enough forward to start.
Otherwise you may have wiring that is pinched.
Logged
AmazenToys
Jr. Member
Reply #2 on:
August 10, 2015 - 02:12:57 PM »
key to start nothing, then key back, if I move the column lock lever back forth, and retry, most times it starts
Logged
HP_Cuda
Sr. Resident
Mopar or No Car!
Reply #3 on:
August 10, 2015 - 02:18:01 PM »
Sounds like it might be time for a new ignition switch.
Only way you will truly know its to pull apart the column and see what's going on.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
August 11, 2015 - 08:41:47 AM »
with a volt meter you can test at the plug at the bottom of the column to see if you have voltage to the yellow wire to the start relay
Last Edit: August 11, 2015 - 08:43:43 AM by Chryco Psycho
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #5 on:
August 11, 2015 - 08:44:41 AM »
Yea...that lock lever thing really has no connection to the ignition switch ....
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
