Author Topic: How far should exhaust tips stick out  (Read 3873 times)
Offline FCC
  • 1973 Dodge Challenger 340
« on: August 11, 2015 - 12:21:21 AM »
Does anyone know how far, factory wise, should the exhaust tips stick out from the valence on a Challenger? Thanks.
Offline YO7_A66
Re: How far should exhaust tips stick out
« Reply #1 on: August 11, 2015 - 06:56:15 AM »
 I hung my new exhaust on my Challenger over last Winter and during this process, I asked the same question and started collecting pictures on the internet. I found that the answer was all over the place. I will attach some photos. This one is shown as a concourse restoration. The following pictures are some showing the tips sticking out at different lengths. I was told that is was personnel opinion so I tucked mine in close to the valence.
Offline YO7_A66
« Reply #2 on: August 11, 2015 - 06:57:19 AM »
Mine looks like this setup. I kept mine tight to the valence (vertical) and only sticking out maybe 3/8" on the top of the tip to the valence.
« Last Edit: August 11, 2015 - 07:02:15 AM by YO7_A66 »
Offline YO7_A66
« Reply #3 on: August 11, 2015 - 06:59:40 AM »
Further out.
Offline YO7_A66
« Reply #4 on: August 11, 2015 - 07:00:39 AM »
 Even more further out
Offline blown motor
« Reply #5 on: August 11, 2015 - 09:23:48 AM »
Mine stick out a bit further than the last pic. It's a Magnaflow system and I think it's too far. Plan on shortening it but just haven't got it done yet.
YO7, do you get any exhaust deposits on your bumper with the tips in that close?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #6 on: August 11, 2015 - 09:59:17 AM »
I liked mine, stuck out about an 1".
Offline rUNCHARGER
« Reply #7 on: August 11, 2015 - 10:39:34 AM »
YO7's purple car is how I remember them coming from the factory.
Sheldon
Offline YO7_A66
« Reply #8 on: August 11, 2015 - 11:28:31 AM »
 ""YO7, do you get any exhaust deposits on your bumper with the tips in that close?""
 No deposites. I just wiped it down over the weekend and did not notice any.
 Note: All of the above pictures were copied from the internet. If I stole your picture, then thank you!  :)
Offline FCC
« Reply #9 on: August 11, 2015 - 06:46:42 PM »
Thanks for posting great pictures! I personally like it sticking out just a little past the valence but not too short.  Thanks.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #10 on: August 30, 2015 - 05:32:00 PM »
Hey, that's my car!  Just to clarify: the photos show the tips when the exhaust was cold.  When the exhaust heats up, expansion occurs causing slight lengthening of the system.  Hence, when the exhaust is at maximum running temperature, the tips stick out beyond the valance about .75" - 1".
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
