Author Topic: Low vacuum on stock 383  (Read 5684 times)
Offline Yellow Submarine
« on: August 11, 2015 - 08:50:38 PM »
Now that the over temp issue on my stock 383 issue has been put to rest I need to figure out why the vacuum is only 12". The engine was rebuilt several years ago but the car was never really driven as it was garaged midway through a restoration. The machine shop indicates a complete stock rebuild including having the cam re-ground to unknown specs. The idle indicates a docile cam, not a thumper.
I have the baseline timing at 12deg. The idle mixture screws at 2 turns. I have tried blocking any and all vac lines to rule out leakage from them. I have not checked for intake manifold leaks yet. I also plan on doing a compression check.
One of my thoughts is the cam may have been ground incorrectly or the cam timing  may be retarded. Anything I am missing?
John :feedback:
70' RT SE 383 Challenger
Factory Five MkIII Roadster (Cobra)
66' Mustang FB (GT 350 Clone)
70' Kawasaki 500 Mach III (H1)
Offline Strawdawg
    • Vortex Buicks
Re: Low vacuum on stock 383
« Reply #1 on: August 11, 2015 - 10:10:49 PM »
Without knowing what cam is in the car, it is really all guessing.
What is the idle rpm?  And what is the cranking compression (when you check it)?
« Reply #2 on: August 11, 2015 - 11:41:01 PM »
EVen if it is a good cam if the cam was installed without degreeing it that could be the whole problem as I have seen cams 11* off just lining up the dots
Offline cudabob496
« Reply #3 on: August 12, 2015 - 05:33:37 PM »
12"?  Is this at idle?
what are cam specs, may be an ok number.
Increase idle?
2011 Kawasaki Z1000
« Reply #4 on: September 07, 2015 - 09:45:15 PM »
Finally checked cold cranking compression today. This is on an engine completely rebuilt in the mid 90's but not driven. It idles a little rough, has low vac at idle. About 1,000-900 rpm, no functioning tach to verify it has about 12" of vac from front base port on factory carb. The cam was reground to unknown specs during overhaul. Piston cr is unknown. Heads are 906's. Plugs are light brown. Plugs #6 and #7 have some darker color and are a little wet with gas or oil, not sure which. Distributor has Pertronix module in it. Base timing is 12deg.
Compression is as follows
1-118, 3-120, 5-120, 7-100
2-125, 4-130, 6-110, 8-120
Any ideas?
John
« Reply #5 on: September 07, 2015 - 10:14:31 PM »
To me it sounds basically like a lame cam in there now , i would be looking at something like the 702 Voodoo with short overlap & duration to build a lot more cylinder pressure this should idle well bring up the vacuum & compression & make the engine a lot more fun to drive . Bad news is also the engine doesn't seem overly healthy as you have a 30% variance from high to low , 15% is generally considered max , although a cam swap may help the compression #s even out & the engine may not have completely broken in & seated the rings etc if it was never driven so putting on miles will help too .
« Reply #6 on: September 07, 2015 - 10:31:10 PM »
Thanks cp. I want to drive it a little even though most of the interior is not in place. When I take it apart is when I would be ok opening it up or swapping it out.
Other things I'm thinking about is are the ignition wires ok as well as the carb. Also someone, maybe you, mentioned the cam maybe indexed wrong. Given the compression does that still seem likely?
John
Offline 734406pk
  • Andy
« Reply #7 on: September 07, 2015 - 10:51:32 PM »
 :iagree: looks like you may have a compression leakage there. Sorry!
« Reply #8 on: September 07, 2015 - 10:58:04 PM »
Yes the cam could still be installed off a few degrees but given the variable of thousands of cams out there I would rather put a good known cam in there than guess , yes you have compression leakage but that could quickly change as the engine breaks in & seals up .
Offline cudabob496
« Reply #9 on: September 08, 2015 - 01:54:14 AM »
vacuum gauge accurate
vacuum leak
carb in tune
2011 Kawasaki Z1000
« Reply #10 on: September 08, 2015 - 04:25:32 PM »
Bob
The carb is another ? It is a stock carter that was probably rebuilt along with the engine in the 90's. I think I will "borrow" the Holley 670 off my Cobra to see if it runs the same.
About how many miles or hours of running do you think it takes for the rings to be considered well seated?
John
Offline cudabob496
« Reply #11 on: September 08, 2015 - 05:23:13 PM »
switch from dino oil to synthetic after 1500 miles
2011 Kawasaki Z1000
Offline 73_Cuda_4_Me
« Reply #12 on: September 08, 2015 - 05:33:38 PM »
How about warmed up compression test, with WOT... fully charged (and charging) battery with all plugs out...
Cold compression can vary 10-15 percent from operating temp engine...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline Strawdawg
    • Vortex Buicks
« Reply #13 on: September 08, 2015 - 06:24:51 PM »
Oops
« Reply #14 on: September 08, 2015 - 07:45:44 PM »
I would put 500 miles varying rpm as much as possible to seat it in , if it has chrome Moly rings 5000 miles won't seat them in .
