Author Topic: Low vacuum on stock 383  (Read 5686 times)
Offline Yellow Submarine
Re: Low vacuum on stock 383
« Reply #15 on: September 08, 2015 - 10:34:18 PM »
Just went back into the garage and tried the #7 that was only 100psi. I tightened up the fitting and got 110psi consistently. That's a bit closer to the others but still low. I'll try to improve the idle a bit or try another carb and drive it an see if that helps.
If all else fails there's always a 440 or Hemi. Ok maybe not a Hemi.
John
70' RT SE 383 Challenger
Factory Five MkIII Roadster (Cobra)
66' Mustang FB (GT 350 Clone)
70' Kawasaki 500 Mach III (H1)
Offline Strawdawg
    • Vortex Buicks
« Reply #16 on: September 09, 2015 - 08:57:09 AM »
I would be tempted to do a leak down test and if it is okay, I would change the cam to something known to work with factory stock components
Sent from my LG-H810 using Tapatalk
Re: Low vacuum on stock 383 (UPDATE)
« Reply #17 on: October 04, 2015 - 10:59:08 PM »
Ok since the last time, I went back to all the cylinders doing another comp check. I was more careful to be sure the screw in connector was tight. I also propped open the throttle blades as I had overlooked this previously. The max compression came back at 120psi +\-about 5-6 psi. So now it's still low but at least somewhat consistant.
I cleaned and gapped the plugs, checked the wires for high or inconsistant resistance. I took an old (but not worn) Holley, put a rebuild kit in it and replaced the Carter and fired it up. It runs basically the same as it did prior to these changes.
It's looking like I need to check the came indexing and maybe change out the cam to a known quantity. I'll let you know how this goes and thanks for all your help.
John
« Reply #18 on: October 06, 2015 - 09:39:03 PM »
This afternoon I found a stand alone tach to see the RPM and went about adjusting the idle on the carb. I placed the vac gauge inline and kept lowering the idle speed then adjusted the two idle mix screws to even it back out. I kept going back and forth until I got it to about 850RPM and maintained 17.5MMHG vac. It idles better than it has before and the throttle response :bananasmi is crisp. I can put it in gear without stalling it. I will try putting a few miles on it and re-check.
John
Offline 734406pk
  • Andy
« Reply #19 on: October 07, 2015 - 08:11:47 PM »
 :iagree: I would do a leak down test on this engine to find out if there is a compression leakage issue here. If no leakage problem is found, your cam timing may be set up late. This would explain the 120 psi compression pressures you are getting. The leak down testers are fairly economical. Summit has them for around $50 or so.
« Reply #20 on: October 09, 2015 - 12:40:33 AM »
Thanks again Andy
