Author Topic: Best hood to cowl seal ?  (Read 7669 times)
Offline Racer57
« on: August 14, 2015 - 11:15:15 PM »
I need a new seal and found this .....  http://www.rosevillemoparts.com/product_info.php/p/seal-hood-to-cowl-70-74-e-body/products_id/8009
Does it seal better than it looks like it would ? I could care less if its "numbers matching". I want something that works. I would think that something like a trunk seal or a tubular style would be better.
« Last Edit: August 14, 2015 - 11:28:16 PM by Racer57 »
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Best hood to cowl seal ?
« Reply #1 on: August 15, 2015 - 01:41:48 PM »
I bought this one and it fit perfect!  I also like this one over other because the pins are already pre-installed and match up with the holes perfectly.  Double check with Dave before ordering but that is the way mine came a couple years ago.
« Reply #2 on: August 15, 2015 - 03:03:01 PM »
I'm thinking of replacing the reproduction one I bought.
It's wavy at the curves like Stroganoff noodles.
Have a picture of the one installed from Roseville?
Offline dfrazz
« Reply #3 on: August 15, 2015 - 04:25:20 PM »
Just a partial shot of it here.  I just let it lay flat for a couple hours and then snapped it right in.
Offline roadman5312
« Reply #4 on: August 15, 2015 - 05:31:07 PM »
        If your using Vintage Air unit, the cowl opening on the right side coming into the heater or factory A/C box gets blocked off, like ours. Were not going to use the seal, more heat out of engine bay. Just a thought.
 :rebel:
Offline Racer57
« Reply #5 on: August 15, 2015 - 10:42:22 PM »
 :rebel:
I don't have air conditioning. I'm getting hot air out of the drivers side vent while the passenger side is cool air. From looking at the seal, I strongly suspect its whats wrong.
Offline tman
« Reply #6 on: August 15, 2015 - 11:23:50 PM »
That's the purpose of the hood/cowl seal, to keep out hot engine bay air out of cool air inlets.  I got this one.  Made in US is something I like.  This one fit great on my Cuda.  Definitely get one with clips installed.
http://www.ebay.com/itm/Mopar-NEW-1970-71-72-73-74-E-Body-Barracuda-Cuda-Challenger-Hood-to-Cowl-Seal-/221820107822?fits=Year%3A1970%7CModel%3ACuda&hash=item33a5823c2e&vxp=mtr
« Reply #7 on: August 16, 2015 - 12:55:36 AM »
I still have yet to see a good picture on this thread of a reproduction hood to cowl seal.
So my question is still in effect.
Wavy noodle type or not? Show me!
Offline tman
« Reply #8 on: August 16, 2015 - 02:49:08 AM »
No noodling here.  Installed about 3 months ago
« Reply #9 on: August 16, 2015 - 03:31:59 AM »
Thanks
Is this a foamy type or an actual rubber type?
Offline solarguy
« Reply #10 on: August 16, 2015 - 08:56:43 AM »
Just make sure you install it with the "U" shape opening facing forward.  I see so many installed backwards.  Dfrazz, your pic looks like opening is facing rearward?
Offline tman
« Reply #11 on: August 16, 2015 - 09:49:11 AM »
Thanks
Rubber.
Offline roadman5312
« Reply #12 on: August 16, 2015 - 03:49:26 PM »
                            Yea, even with a good cowl/hood seal you will get some hot air. I'm contemplating fabing up some aluminum plates to completely block any air/ water to enter the cowl.  They will be fashioned to fit under the screens, painted black to match the cowl.  It will keep hot engine air from heating up the lower cowl inside the car.
        :rebel:
« Last Edit: August 16, 2015 - 03:51:45 PM by roadman5312 »
Offline Racer57
« Reply #13 on: August 17, 2015 - 11:00:37 PM »
        :rebel:
I had thought along the same lines but was going to cut some 1" or thicker Celotex insulation to fit and paint it black. But I decided I want some air flow.
Offline roadman5312
« Reply #14 on: August 18, 2015 - 07:56:05 AM »
We fabricated the block off plates yesterday, now will get painted and installed under screens.         :rebel:
