Author Topic: 4 wheel discs. What MC to use? Booster needed?  (Read 1277 times)
Offline 69CHARGERMD
« on: August 15, 2015 - 11:25:13 AM »
Need some input on my brake system. 1970 Challenger. Originally with four drum manual brakes.
I am putting on four wheel disc brakes.  I bought the conversion kit from Dr. Diff.
 Question I have is what master cylinder to run and do I need to run a booster for the system?.
Thx. Doug.
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 4 wheel discs. What MC to use? Booster needed?
« Reply #1 on: August 15, 2015 - 01:32:31 PM »
I switched my '71 Challenger from drums to 4 disc, added a MC from Napa and kept the stock booster.  I was nervous about the single diaphragm booster so I added a vacuum pump in the trunk that was way too loud.
I eventually bought a hydro-boost system eventually and that would be my recommendation.  Pricey but worth it in the end.
http://www.tallonhydraulics.com/store/index.php?main_page=index&cPath=54_60
Offline Katfish
  • 70 Challenger
« Reply #2 on: August 15, 2015 - 01:54:31 PM »
No need for a booster.  You'll have better feel without it.
« Reply #3 on: August 15, 2015 - 05:13:19 PM »
make sure you do not have a residual pressure valve in whatever master you do use , the factory masters use a rubber valve behind the brass insert where the line screws into the master , use a drywall screw to pull the insert & remove the valve .
 If you want boost I would use a hydro boost if you have power steering , the later 2 bolt alum masters work great & have a large shared reservoir
Offline BergmanAutoCraft
« Reply #4 on: August 16, 2015 - 06:43:18 AM »
The alum 2 bolt master 1 1/8" bore is common. I love hydro boost as well as well as being a dealer. Some systems can't be run manually and work properly.
