Author Topic: 1973 Plymouth Cuda - Bit of an Issue..  (Read 15101 times)
Offline 734406pk
  • Andy
Re: 1973 Plymouth Cuda - Bit of an Issue..
« Reply #45 on: October 19, 2015 - 09:38:14 PM »
Thanks!  On to the next hurdle..the CA DMV.  That shouldnt be too bad, other than them taking money I could be putting into the car  :swear:
Keep us updated! This car needs to be driven- good luck!
Offline Dads440
« Reply #46 on: December 22, 2015 - 03:12:04 PM »
Hey guys..everything is good to go with CHP, CA DMV and insurance..I'm legal!  I've got about a million things to do..but I think the first hurdle to jump is an issue Ive had with the car not wanting to start again after running.  I can go out, crank it now, drive it around for about 15 minutes, come back and crank/crank/crank til the battery or starter dies.  It seems to be relative to temperature (just a guess) because it's only if the car has run for a good while.  If I start it and run it (not drive it) for 5 minutes or so..it'll crank back up.  My Dad was thinking timing..and we both had compression thoughts.  Any ideas?
As always, thanks for the help!
Darren
Offline js29no
« Reply #47 on: December 22, 2015 - 03:24:29 PM »
sounds like ignition to me! I have seen anything from an ignition coil, pick up coil, module, do that. how good are you wiring?
Offline 1 Wild R/T
« Reply #48 on: December 22, 2015 - 03:59:22 PM »
Glad you got the paperwork taken care of.... For your next issue I agree it sounds ignition related but could be fuel....   Try pulling the coil wire out of the distributor cap, lay it so the end is maybe 1/4" from something steel like the intake or valve cover & watch for spark while you have someone else crank the engine.....
« Reply #49 on: December 22, 2015 - 11:30:04 PM »
Pick up coil can shut down with heat , check the gap too
Offline Dads440
« Reply #50 on: January 07, 2016 - 05:51:11 PM »
Thanks for the ideas guys.  Been sorta busy traveling over the Christmas/New Year holiday.  I'll look into those ideas in the coming weeks once the Southern California rains die down!
Thanks,
Darren
Offline 70chall440
« Reply #51 on: January 07, 2016 - 06:33:16 PM »
Sounds like heat soak on the coil, I have had the same issue in the past. Throw a new coil into it (get a cheap one from a parts store if you don't have one laying around) and try it out. If it works, you can deal with that later if you are going to do some performance upgrades.
If this doesn't work, look at the ECU on the firewall (big square box, probably black with a round or kind of triangular plug with a single Philips head screw in the center); I have had them act like this as well.
Current Mopar
Past Mopars
