My first 440 Build
Author Topic: My first 440 Build  (Read 5379 times)
Offline Strawdawg
    • Vortex Buicks
Re: My first 440 Build
« Reply #15 on: August 22, 2015 - 11:41:24 PM »
Looks like it will take a rebore to me...but as CP said, you cannot really tell from pictures
Offline Cuda4u
« Reply #16 on: September 17, 2015 - 05:43:29 PM »
 forumpete
Jr. Member
« Reply #11 on: August 20, 2015 - 05:19:31 PM »
Quote
Well...it looks like 512 stroker, stealth heads, and voodoo cam is the route I'm going with.  Damn, and I was just going to replace gaskets :/
Report to moderator     Logged
This is something I would like to do to my 70 440 six pack as well.
Engine is what you would by in 1970 except for the mopar orange ignition box. Was looking at heads, cam, headers, ignition and reading this post maybe not so simple. Drive it the odd weekend never in the rain. What is a ballpark price on this. I would remove and install engine.
Offline 73440
« Reply #17 on: September 17, 2015 - 08:55:25 PM »
Some info from 440 source  http://www.440source.com/strokerkits.htm
Damn I may just do this also!!!
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #18 on: September 17, 2015 - 10:19:26 PM »
forumpete
Jr. Member
Quote
 It really depends on the labor rate but we could do a 512 for around 7K depending on parts used , the stroker kit is 2k including crank, rods, pistons, rings & brgs + balancing  + cleaning, machining & assy + head, cam, rockers, intake, etc
Offline sassygreen
« Reply #19 on: September 18, 2015 - 09:09:18 PM »
check out my budget 440 motor thread. My cylinders and crankshaft looked a lot like yours. rent some micrometers and check cylinder walls for out of roundness. crankshaft can be checked with a micrometer to see if it is still in spec. check out my thread before you go and spend thousands on stuff you do not need. I built mine for around 2,300 dollars. check it out the thread is called [ RV low budget].
Offline Cuda4u
« Reply #20 on: September 18, 2015 - 11:11:13 PM »
I'm going to read up on this 512 based on 440 block. Is this approx a 500hp steetable package.
And keeping the 6 pack carb setup?
« Last Edit: September 18, 2015 - 11:15:46 PM by Cuda4u »
« Reply #21 on: September 18, 2015 - 11:22:07 PM »
the ones I was building were dynoed with 650 + hp gross rated & 400+ RWhp idled well & no need to run past 6000 rpm as peak number were below that
Offline Spartan040
« Reply #22 on: September 20, 2015 - 08:12:19 AM »
650 gross and 400+ WHP? Why the huge drop?   :clueless: not criticizing, I just want to know
Offline TelisSE440
« Reply #23 on: September 20, 2015 - 03:59:32 PM »
I have the same question, but more in general how much HP is being deducted on E Bodies going from gross to net?
