Author Topic: Planetary gears  (Read 670 times)
Offline msbaugh
Planetary gears
« on: August 21, 2015 - 06:42:18 PM »
Rebuilding my 727... I'm sliding everything onto the output shaft and I'm having a lot of trouble sliding on the sun gear and shell. How easy should this be sliding on the output shaft, it's so tight that I can't get any free play to adjust clearance, the bushings are so tight that it won't allow anything to move up and down and it won't rotate on the shaft without a lot of force.
I had a shop install new bushings I guess they were the wrong ones?
« Last Edit: August 21, 2015 - 06:44:49 PM by msbaugh »
Offline 1 Wild R/T
Re: Planetary gears
« Reply #1 on: August 21, 2015 - 07:12:30 PM »
More likely they didn't support the bushing properly & it collapsed slightly.... Sometimes trying to do the right thing does more harm than good... Often when O/H a torque flight I use the bushings.... & I have all the tools to replace them.. Plus a lathe so I could make what ever driver I need....  If the bushings are tight I leave them alone...
Offline msbaugh
Re: Planetary gears
« Reply #2 on: August 22, 2015 - 07:18:59 AM »
They weren't even bad either just decided to replace them all... Guess I'll be dropping them back off. Lesson learned I guess...
I'll give them the output shaft this time so they can make sure it fits
« Last Edit: May 01, 2016 - 10:54:54 AM by msbaugh »
