Author Topic: 383 6 pack ?  (Read 2787 times)
Offline Racer57
383 6 pack ?
« on: August 21, 2015 - 11:38:26 PM »
Just for the sake of argument.....
If you had a good running stock HP383, would you put a 6pack on it ?  :D
Offline cudabob496
Re: 383 6 pack ?
« Reply #1 on: August 22, 2015 - 01:24:42 AM »
no, headache to tune, and will make more power with single 4 barrel
2011 Kawasaki Z1000
Re: 383 6 pack ?
« Reply #2 on: August 22, 2015 - 02:05:04 AM »
 unless you want the looks , the 6 pack will run $2600 a very good carb + intake under 1k
Offline schtick
Re: 383 6 pack ?
« Reply #3 on: September 09, 2015 - 09:07:56 AM »
I had added a six pack to my ex- 71 Cuda in 1992. Only about $1000 back then. Even had a sign shop make a silk screen 383 Six Barrel for the air cleaner. I loved the set up. Was the car faster? In my case, yes. 71's had a 600 cfm Holley as stock. With the old hemi grind purple shaft, and CPPA heads (remember those?) Headman the headers and 3.23's ans 4sp, that car ran 13.8's all day and I drove it everywhere. Never touched the carbs.
Offline GreenFish
Re: 383 6 pack ?
« Reply #4 on: September 10, 2015 - 10:06:52 AM »
NO, I would not, there is no benefit other than the cool factor. But if that's what you are aiming for. Then sure why not, go for it. You don't have to explain to me why you would do something just because it would be cool.
Offline Road_Runner
Re: 383 6 pack ?
« Reply #5 on: September 10, 2015 - 09:57:51 PM »
I absolutely would, did back in the 70's & 80's and plan on doing again with the Roadrunner when I rebuild  the original 383 soon.  Even fits into the Airgrabber hood setup perfectly, too.  It  does look very cool, Mopar sold this setup back in the 70's - early 80's so its period correct if that matters.  And the sound, I loved hearing all those carbs opening up together!   More complex than a 4 bbl sure, but worth it to some of us.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline 4406v
Re: 383 6 pack ?
« Reply #6 on: September 11, 2015 - 03:57:35 PM »
I added a six pack to my 440 in my old Challenger. There is nothing better than a finely tuned six pack at W.O.T.!!!!  It got pretty good gas mileage (who cares?) when cruising on the highway and if a passing situation presented itself HOLY SMOKES!!! would that thing come alive!!! Mine was an automatic and you might not get the same results with a stick car but it's still cool.
"Live for today, Tomorrow never comes"
Offline cudabob496
Re: 383 6 pack ?
« Reply #7 on: September 11, 2015 - 07:30:29 PM »
an AFR meter would certainly make tuning a 6 pak easier
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
Re: 383 6 pack ?
« Reply #8 on: September 14, 2015 - 08:48:05 PM »
 :iagree: expensive? Yes. Cool? Absolutely!!!
