If you want to make your own coolant recovery system and want to maintain a stock look, its pretty easy. Just use your windshield washer tank, but it has to be a manual one. Otherwise, you change it to manual and need some hoses and correct radiator cap for closed system. Then you can fill the radiator to the top. Or to keep it stock, don't fill to the top as mentioned earlier.
