Tony I would look at hydro boost as a better option if you have power steering ,
if the pedal is dropping after being pushed & held the master is leaking internally , the booster may be leaking also internally being 45 years old now
The masters I have seen use the same nut size on the lines but the thread size is different fortnt to rear so the lines cannot be connected backwards
