Author Topic: What is this...  (Read 1355 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
What is this...
« on: August 24, 2015 - 12:40:58 PM »
On my rear alxe - Looks like a second valve for the rear end ???
I have a 71 cuda with a bunch of pirated parts from a roadrunner I believe.
Car has Power Brakes - disc front and rear drum
This is on the rear axle ...
I think I have proportioning valve issues potentially and noticed that I needed to rebuild both rear drums ... in yanking the wheels, i found this guy.  Goodness knows if it's adjusted or what it even is if it is an adjuster.
Want one?  Got one! ... finally
Offline HP_Cuda
  • Mopar or No Car!
Re: What is this...
« Reply #1 on: August 24, 2015 - 12:49:06 PM »
That is the junction for the rear brakes.
Notice you have one hard line coming down the drivers side, then into a soft line into said junction box. Then over to both wheels.
If you are looking for a proportioning valve that would be in the engine bay near the master cylinder - if you have one(PV).
Offline acudadude
Re: What is this...
« Reply #2 on: August 24, 2015 - 01:19:30 PM »
Also axle vent bolt?
Offline HP_Cuda
  • Mopar or No Car!
Re: What is this...
« Reply #3 on: August 24, 2015 - 01:20:24 PM »
Yes the junction slides over the vent.
Offline wantone
Re: What is this...
« Reply #4 on: August 24, 2015 - 02:02:58 PM »
IS this something that requires maintenance?   The car is still very new to me so I wonder if I need to do anything when addressing the brake bleeding or rebuilding of drums etc...
PS -  Is the rear-end self-venting through that valve?
Offline TelisSE440
Re: What is this...
« Reply #5 on: August 24, 2015 - 02:19:11 PM »
Yes the valve works both as a vent to the rear axle and as holding for the brake line tee on the rear axle housing. Maybe sometimes you'll see that the area around it after a cruise will be a shade wet from the extra warm gear oil. About maintenance, when I took it off I just blew air in it to remove some sludge like material blocking it. Nothing more, no problems until now.
Offline azievinger
  • one Happy Island
Re: What is this...
« Reply #6 on: August 24, 2015 - 03:33:45 PM »
I had to replace mine's. Lost power to the rear drum brake, and this was the issue causing to lose power. front continued to work though.
Offline wantone
Re: What is this...
« Reply #7 on: August 24, 2015 - 03:51:54 PM »
Cool... i'll rebuild my rear brakes and then see if they work.
PS - I have no idea how to tell if my proportioning valve works.  We'll have to see there too I suppose.   I'm not sure if I want to go with an adjustable one vs standard parts replacement.
