Engine is still cutting out, but not as frequently. Taking measurements again at the ballast resister:
During START the Lower Plug BROWN should have about 12VDC,
12.1vdc in start position
check,
When key released goes to RUN the upper plug BLUE should get 12VDC.
12.5vdc while running (it
no longer jumps down from 1 back up to 12vdc sporadically)
In the Run position the lower plug GREEN/Red wire should show power reduced to about 5VDC going to the ECU
PROBLEMthe lower plug BROWN wire will drop to about 8VDC going to the coil, this is your run power after the resistors drop the voltage
8.5vdc while running
with occasional drops to 1-2vdcTwo observations from before:
1. it seems the ballast resister is not reducing voltage as it should coming out of the green/red wire, but perhaps is as it comes out of the brown wire.
confirmed to be correct given the above now that the ignition switch has been replaced2. while running, the voltage is jumping all over the board. is this normal? if so, should i be looking at the ceiling/max voltage for the readings?
no longer happening as often, but still happeningSo I'm guessing the next step is to replace ballast resistor?
JF
