Author Topic: 440 six-pack cam ?  (Read 5499 times)
Offline tancuda
440 six-pack cam ?
« on: August 21, 2002 - 08:51:34 AM »
Hi all, I will built a 440 six-pack for a 70 cuda and I want your opinion on the cam. It will have 3.23 sure-grip, stock exhaust
manifold, stage I ported head (Hughes Engines),good aftermarket rod, forged piston and the compression will be around 9.5:1.
Here's my choices :
Comp Cams hydraulic roller #12-423-8
224-230deg. duration @ .050" and .502" .510" lift.
Hughes Engines  hydraulic#HE 2330 BL
223-230deg. duration @ .050" and .504" .515" lift.
I want strong low end torque and power untill 6000 rpm.
If somebody knows any dyno test with these combo please
let me know.
Thanks
Pat
Re:440 six-pack cam ?
« Reply #1 on: August 21, 2002 - 12:31:55 PM »
  Does comp make a small hydraulic roller for the 440 now ? How are the holding the rollers straight on the cam ?
I have used the Hughes cams & they work well but I don`t have any dyno #s for you  , I would lean towards the Hughes cam if the Comp uses link bars between the lifters , I`ve seen a# of the link bars fail
Offline tancuda
« Reply #2 on: August 21, 2002 - 12:37:18 PM »
Sorry my friend, it's my mistake about roller cam in 440.
How was vacuum with the cam you have used ??
Was it more than 230deg. duration ?
Thanks
Pat
« Reply #3 on: August 21, 2002 - 12:44:47 PM »
 I can`t remember  the exact vacuum with that cam , I`ve installed too many this summer already but the vacuum will be better than the .474 Mopar cam & it is a mild profile so the vacuum will be decent
Offline tancuda
« Reply #4 on: August 21, 2002 - 12:53:32 PM »
What could be the bigger Hughes Engine cam I can put
with my 3.23 and stock exhaust manifold but ported head ??
And still have plenty of low end torque.
Thanks
« Reply #5 on: August 21, 2002 - 01:14:22 PM »
 I wouldn`t go bigger than the 2330 as you don`t need a converter with it & it will have lots of bottom end
Offline tancuda
« Reply #6 on: August 21, 2002 - 01:18:08 PM »
Thanks to you and congratulation for your 500th post !!!
« Reply #7 on: August 21, 2002 - 01:19:02 PM »
Thanks I wasn`t even paying attention  ::)
 OOOps 501 now
« Last Edit: August 21, 2002 - 01:19:25 PM by Chryco Psycho »
Offline sixpackcuda
  • Six pack to go!!!
« Reply #8 on: August 22, 2002 - 11:24:03 PM »
What does Hughes recommend? They should be able to hook you up.
http://www.sixpackcuda.us
In-Violet 70 Cuda 340 W/6 Pack
Mopar Rules!!
IF IT DOESN'T WEAR A STAR, IT'S NOT A REAL CAR!!
