Well I tried to bleed the brakes which turned into an issue. I couldn't get any fluid to the rear brakes and determined that the proportioning/metering/distribution valve was causing me some pain. So I removed it, disassembled it (had to use some heat) and cleaned it up. I also removed my adjustable proportioning valve and checked it as well. Now I have to put it all back together and try again.
I have a Motion Products power bleeder, for flat top master cylinders (like Mopar) adapter, however due to my clutch reservoir is in the way, so I have attempted to make a Mopar specific power bleeder adapter... pretty much redneck engineering but we will see how it works soon.
