Author Topic: 73 Road Race Cuda  (Read 201169 times)
Offline 70chall440
Re: 73 Road Race Cuda
« Reply #765 on: January 27, 2018 - 03:27:22 PM »
Do you have a headlight switch and a wiper switch schematic? I think I have them figured out but it would be nice to see what you did
Current Mopar
Past Mopars
Offline 70chall440
« Reply #766 on: January 27, 2018 - 06:39:55 PM »
So I have reached a bit of an issue with regards to the dome light, more specifically the door jam switch connectors. I have the wiring that came from the car but cannot ID the wires that go to the door jam switches. I ordered new switches and they have 3 round holes in the back and I cannot find anything that remotely looks like. I also located what I believe to be the original switches and one has two spade connectors and one has only one receptacle for something like a probe or bullet connector.
Any input here? Here is a pic of the door jamb switch that inline sells which I do not think it correct. Looking at various wiring diagrams, there are/were switches that had 3 connections but I do not think mine did. The second picture is what I think I need.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #767 on: January 27, 2018 - 06:41:46 PM »
try again
Current Mopar
Past Mopars
Offline 70chall440
« Reply #768 on: January 27, 2018 - 07:42:43 PM »
I think I got it figured out; I have the wrong door switches
Current Mopar
Past Mopars
Offline GoodysGotaCuda
« Reply #769 on: January 27, 2018 - 09:03:49 PM »
I don't have what I did exactly, I just traced the factory harness diagrams and used an ohmmeter. I also left the wires tagged in the dash, so if I have to go in there, I know what I was thinking.
I used these but from Rock Auto. Seem to work fine, but I have no factory wiring.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 70chall440
« Reply #770 on: January 27, 2018 - 11:50:49 PM »
I dont have any factory wiring either, I do have small things and am trying to reuse connectors; meaning the factory plastic connectors which I remove the spade connectors and put new ones in. There are a few things that I haven't been able to source so I have had to reuse the factory pieces (like the 3 bullet connector blocks they used to connect things like the glove box light and the ash tray light. I am trying to find the actual bullet connectors so I dont have to reuse them.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #771 on: January 27, 2018 - 11:52:36 PM »
I finished trimming up the EFI harness and got it reinstalled. Looks so much better than just leaving it as it had a lot of extra wire.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #772 on: January 28, 2018 - 12:16:23 PM »
Getting the main harness set up.
Current Mopar
Past Mopars
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #773 on: January 28, 2018 - 10:12:43 PM »
Making progress!
Looking forward to you firing it up.  :2thumbs:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline 70chall440
« Reply #774 on: January 28, 2018 - 10:27:59 PM »
Yea me too, its been a long time  :bigsmile:
I started on the gauges today.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #775 on: January 29, 2018 - 11:22:15 PM »
this wiring work is very tedious and slow, but it is interesting. Spent quite a lot of time wiring up my headlight switch and dimmer switch. I was able to test and confirm that I can use my original panel dimmer switch with my Speed Hut gauges.
My one issue now it the wiper switch; I know how to wire it but Ma Mopar used a 12g wire to power it and the harness I am using provides a 16g power wire. I am a bit concerned tat the wiper may draw more power than the harness manufacturer imagined, or MA Mopar used 12g because that wire ties into another line that uses 12g. Anyone got any insight, opinion, etc.?
Current Mopar
Past Mopars
« Reply #776 on: January 30, 2018 - 12:11:58 AM »
I'm not sure off hand what it is, but testing how much current that wiper motor pulls will tell you. I have an inline ammeter that replaces a fuse, a pretty neat little tool.
1976 Dodge Warlock
Offline 70chall440
« Reply #777 on: January 30, 2018 - 12:19:32 AM »
I emailed the harness manufacturer and asked them. I suppose I can test the wiper motor, just have to figure out how to do it.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #778 on: January 30, 2018 - 03:00:40 PM »
Ok, I heard from the harness manufacturer and they are saying that the 16g wire is good. I am going to check the fuse and see what that says.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #779 on: January 30, 2018 - 03:01:39 PM »
I just discovered that Y1 has a AAR/TA fiberglass base plate for like $125... i ordered it with the seal and a new filter.
« Last Edit: January 30, 2018 - 03:26:03 PM by 70chall440 »
Current Mopar
Past Mopars
