73 Road Race Cuda
Author Topic: 73 Road Race Cuda  (Read 201013 times)
Offline YellowThumper
  • I left the snow for this?
Re: 73 Road Race Cuda
« Reply #930 on: May 03, 2018 - 01:07:47 PM »
Another item I think would significantly change the "visual" is window tinting.
If there is tint and it is dark, all will blend in more uniformly.
Offline 70chall440
« Reply #931 on: May 03, 2018 - 01:17:21 PM »
I agree but here in WA state, tinting is very limited. I have to check again but I asked a glass company once and as I recall I couldn't tint enough to make a difference.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #932 on: May 03, 2018 - 01:23:52 PM »
I was able to get a few small things done. The weather has turned nice here and I was put on my wife's work farm immediately..  :bigsmile:
Got the steering column sorted mostly. Still need to do a few small things.
I also modified the package tray cover. I am running a gps speedo so I needed to install the antenna. I am thinking about covering the package tray cover with some fabric but  haven't decided yet.
Current Mopar
Past Mopars
Offline redo1973
« Reply #933 on: May 03, 2018 - 08:31:01 PM »
I covered my tray with black vinyl.  The same vinyl as the seats.  It looks pretty clean.
« Reply #934 on: May 03, 2018 - 10:09:28 PM »
I covered mine in a semi heavy black cloth. Do you see the speakers? Neither do I or anyone else. Doesn't show in pic but it has fairly large thread that gives it a bit of texture as well. I recommend...
Offline 70chall440
« Reply #935 on: May 04, 2018 - 12:28:42 AM »
So did you guys spray the cardboard with adhesive and stretch the fabric over it? I am thinking a thin black material of some sort.
Current Mopar
Past Mopars
Offline GoodysGotaCuda
« Reply #936 on: May 04, 2018 - 11:46:42 AM »
Are you running dash speaker? I mounted my gps sensor under the speaker grille there, works great.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 70chall440
« Reply #937 on: May 04, 2018 - 12:36:36 PM »
Yes, I have a dash speaker plus I already cut out the package tray cover so I am committed.
Current Mopar
Past Mopars
Offline redo1973
« Reply #938 on: May 04, 2018 - 09:18:21 PM »
Yes, we used adhesive spray on the vinyl but I'm not sure about fabric.
Offline 70chall440
« Reply #939 on: May 04, 2018 - 11:44:21 PM »
ok, thanks.
Current Mopar
Past Mopars
« Reply #940 on: May 07, 2018 - 12:45:20 AM »
For mine I only used adhesive on the underside. Top face no glue.
Offline 70chall440
« Reply #941 on: May 07, 2018 - 11:40:51 AM »
I thought of that method as well. I will probably use the adhesive on the top side
Current Mopar
Past Mopars
Offline MoparCar
« Reply #942 on: May 07, 2018 - 07:59:08 PM »
Did you have to use a steering wheel adapter for your aftermarket steering wheel? If so, which did you use?
Thanks, Wes
Offline 70chall440
« Reply #943 on: May 08, 2018 - 01:19:33 AM »
Yes I had to use an adapter, I took the adapter that came with the wheel and machined it down and then adapter it to a Ebody can. The column I am using is a 28” street rod GM type shaft so there was a lot of fabricating that had to be done to get it to for. The issue is that I refused to spend $800+ on an idit or flaming river column so I made my own.
Current Mopar
Past Mopars
Offline MoparCar
« Reply #944 on: May 08, 2018 - 08:55:29 PM »
Got it. I had thought your column was a stock column when I saw the crush can. Nice work!
Wes
