Sure, but I should state up front that I am not done with it.
I used a 3/4" t universal molding (CRL PN#T110). It has an adhesive on the wide side which I put on the body, it turns around the corners pretty well, but keeping it there is the key. The adhesive is pretty decent but the corners are difficult so I am thinking about using 2 things; first is I think I am going to replace the adhesive with 3M double sided tape, second is that I am going to use some adhesive in the channel to help hold the molding and help to seal the glass. I believe the glass is sealed, but I want to be sure.
I recently ordered some other molding; also a T molding but it uses buytl tape in the glass channel (its a part of the molding that sits around the edge of the glass). The molding I have now is universal/generic and doesn't really grip the glass which is why I believe I need some adhesive in the channel to help it.
If you are interested, I will get some pictures.
