Author Topic: '71 Barracuda Crossmember  (Read 2055 times)
Offline Claudia
« on: August 28, 2015 - 12:54:04 PM »
Can anyone tell me if the transmission cross member is the same regardless if the car is a small block / big block or a manual / automatic setup?
Re: '71 Barracuda Crossmember
« Reply #1 on: August 28, 2015 - 04:11:28 PM »
Same part manual or auto 71-74
Offline anlauto
« Reply #2 on: August 28, 2015 - 04:43:36 PM »
Yes and NO  :nono:
First off....Are we asking about the transmission cross member welded to the floor of the car or the removable transmission mount ?
Mr. Psycho is correct in saying the same set-up is used for both manual and automatic through-out the years, BUT they are NOT the same part through-out the years...
The 70 welded cross member is different from all other years, and the removable mount is the same for 70-71 but different from 73-74 as is the welded cross member in 73-74
Offline Claudia
« Reply #3 on: August 31, 2015 - 05:00:48 PM »
anlauto: My apologies, I was asking about the removable cross member section.
Offline anlauto
« Reply #4 on: August 31, 2015 - 05:10:58 PM »
That's okay....There are two styles 70-71 and 73-74....Doesn't matter if it's auto or standard.
Offline Claudia
« Reply #5 on: September 01, 2015 - 07:43:55 AM »
Automatic or standard does not matter either?
Offline anlauto
« Reply #6 on: September 01, 2015 - 08:22:37 AM »
Correct :2thumbs:
Offline Moparparts
« Reply #7 on: September 01, 2015 - 11:02:47 AM »
Here are the applications and part numbers for the removable trans crossmembers. Each part number is correct for automatic or manual transmission
70 E-Body part # 2962074
71 E & B-Body built up to June part # 2962074
71 E & B-Body built after June part # 3583188
72 E & B-Body part # 3583188
73-74 E & B-Body part # 3642794
70-72 E-Body & 71-72 B-Body will interchange but 73 -74 will not interchange with a 70-72 E or 71-72 B
Hope this info helps with your search so you get the correct part
Offline Claudia
« Reply #8 on: September 01, 2015 - 04:53:32 PM »
Really great information!  Exactly what I needed!  Thanks!
