Author Topic: 1970 BARRACUDA TAIL LIGHT ASSEMBLY  (Read 758 times)
Offline 70 Grand Coupe
« on: August 28, 2015 - 06:08:06 PM »
Hi Ya'll,
I am having difficulty finding a schematic, picture or procedure to assemble the tail lights to my car. The car was stripped down when I purchased it and now its time to put her back together. So what I have is the tail light assembly with a new foam gasket on, do I place that on the inside of the trunk and then attach the tail light bezel from the outside? So in theory, the (4) small threads/nuts from the bezel are holding the whole tail light assembly to the car?  :clueless:
Thank you in advance.
 :canada:
Regards,
Darcy
Offline 4 speed fish
Re: 1970 BARRACUDA TAIL LIGHT ASSEMBLY
« Reply #1 on: August 31, 2015 - 12:53:30 PM »
Yes ,you are correct.I would lightly glue the gasket to the housing so when you put the housing in the gasket will stay in place.The tail light outer bezel has a thin  gasket also.
