Author Topic: Bell housing B to E Body  (Read 1648 times)
Offline mauls
« on: August 31, 2015 - 10:04:14 PM »
I found a local bell housing, casting number 2468372, and from what I found online, it's from a 383 B body.  I was curious if this would fit a 70 E body with a 440?  I have the A-833 Trans to pair with it.
Thanks in advance
Kansas City, MO
1970 Challenger &2010 Challenger SRT8 six speed
Offline anlauto
Re: Bell housing B to E Body
« Reply #1 on: August 31, 2015 - 10:20:51 PM »
Might have the wrong size bearing retainer hole  :2cents:
Offline 1 Wild R/T
« Reply #2 on: September 01, 2015 - 02:28:07 AM »
65-66 B & C body 10.5" ...
« Reply #3 on: September 01, 2015 - 12:06:53 PM »
IF wild is right then you will need a 130 tooth flywheel & I would recommend a 10.95" clutch not a 10.5" with that
Offline 1 Wild R/T
« Reply #4 on: September 01, 2015 - 12:48:18 PM »
IF XXXX is right then you will need a 130 tooth flywheel & I would recommend a 10.95" clutch not a 10.5" with that
  Insert Above   ^^^^^^^^  If Chryslers parts books are right...  ^^^^^^^^
Offline anlauto
« Reply #5 on: September 01, 2015 - 01:06:09 PM »
A quick call to Wayne at Brewers  :worshippy and you'll get an answer to your questions...I would be concerned about the bearing retainer hole size, I know they changed through the years. :2cents:
Offline mauls
« Reply #6 on: September 01, 2015 - 04:40:55 PM »
yeah I may give them a call.  This is my first experience with bell housings on an older vehicle so I'm not sure.  Which bearing is the issue?  I believe my trans is set up for a B and e body, it has both of the shift mount positions.
Thanks for the info so far
Kansas City, MO
« Reply #7 on: September 02, 2015 - 03:24:49 AM »
the front brg retainer is the issue , it came in 3 sizes , 4.35 using the 307 brg  , 4.80 & 5.12 " diameters both using the larger 308 brg  , the 5.12" retainer can be easily machined down to 4.80 to fit the 4.80 belhousing but you are sunk if you have a 4,35 hole in the belhousing with either of the larger retainers diameters . If you have the 4.35 retainer on your trans there are adapter rings so you can use the 4.80 belhousing
