Author Topic: should i change intakes?  (Read 4517 times)
Offline cordodge
« on: September 01, 2015 - 04:44:28 PM »
Just looking at this intake,its an edelbrock  it is single plane and is the same as the stock intake so my breather would fit. just not sure if I will regret removing the barton type intake on the 572?? and going from a single carb to two would I have tuning issues
thx bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline cudabob496
Re: should i change intakes?
« Reply #1 on: September 01, 2015 - 05:00:30 PM »
single carbs make more power, unless you have a tunnel ram intake.
2011 Kawasaki Z1000
Offline dutch
« Reply #2 on: September 01, 2015 - 05:14:31 PM »
why is that?   :dunno:
twins on a hemi sure looks cool.  Too bad it`s only a 572. Loose any power and you`ll move backwards at the strip...  :biggrin:
*** Bart ***
Offline cudabob496
« Reply #3 on: September 01, 2015 - 05:36:41 PM »
Single carbs make more power because its a proven fact on dynos. I suspect there is better fuel
atomization and air/fuel flow into the heads, with a single carb.  Rarely see dual carbs at a race track,
compared to big single Holley Dominators.
2011 Kawasaki Z1000
« Reply #4 on: September 01, 2015 - 06:00:44 PM »
I would not switch
Offline roadman5312
« Reply #5 on: September 01, 2015 - 06:04:06 PM »
[/quote
                Well then it makes no sense that Hemi's came with dual quads, same as Fords FE 427's, and least we forget 4 speed, dual quad,  positraction 409. All of which, at one time or another dominated NHRA, and NASCAR.  And back then the corporate bean counters would shave a nickel off the cost of building a car, so they would have gone nuts shaving a carburetor. Just sayin.
        :rebel:
Offline roadman5312
« Reply #6 on: September 01, 2015 - 06:06:50 PM »
I would not switch
Offline cordodge
« Reply #7 on: September 01, 2015 - 07:39:18 PM »
Ok guys thanks for the comments, maybe I will leave well enough alone.
bruce
2007  Dodge Ram 4x4
« Reply #8 on: September 02, 2015 - 03:08:08 AM »
Until the late 60s there was no Dominator carbs so to get a larger carb you needed more than 1 , I still own a 4160 style 950 cfm 3 barrel from the late 60s , in Nascar the Hemi used a large plenum crossram intake with a single dominator carb recessed into the middle , not multiple carbs .
 like this ....... ok so I downloaded a picture but cannot find it on this puter  :banghead:
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: September 02, 2015 - 10:29:02 AM »
I guess you are talking about the bath tub manifold?  I think they made it with at least three different tops.  Here's a pic of one for a 4150 (not the three barrel) which was a 4160, I think.
Worked very well as I recall.  I think Brad needs one of these to top off his engine :)
Offline Oldschool
  • Member Since 9-05-06
« Reply #10 on: September 02, 2015 - 10:45:11 AM »
I'm thinking that you need plenty of carb for a 572 Hemi.  What size is on it now?
Ken  --  In Georgia
Offline dutch
« Reply #11 on: September 02, 2015 - 11:29:28 AM »
wow... just as big as a bathtub too....  you don`t want  a backfire in there  :scared:
*** Bart ***
Offline cordodge
« Reply #12 on: September 02, 2015 - 01:00:18 PM »
Hey ken, yeah haven't fired the motor yet, I asked that question here and the consensus was a 950cfm as it is just a crate motor not the monster you have.
bruce
2007  Dodge Ram 4x4
Offline cudabob496
« Reply #13 on: September 02, 2015 - 09:02:54 PM »
Good thing its not made of iron!  200lb intake!
2011 Kawasaki Z1000
Offline Road_Runner
« Reply #14 on: September 10, 2015 - 10:13:12 PM »
If old school cool counts for anything, I'd consider the 2x4 setup.  Like you said, your motor is not a max effort high HP setup already, and 2 fours just look right on Hemi's in my opinion for what that's worth!
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
