Author Topic: BIG BRAKES  (Read 1867 times)
Offline john h
BIG BRAKES
« on: September 03, 2015 - 12:18:53 PM »
I have standard power disk brakes up front being that my Cuda is a 73.  I'm wondering about what people are doing for better disk setups.  I see a lot of kits for conversion form drum to disk.  Do we have to change out our spindles?  Is there a decent priced kit with just The larger better rotors, calipers and pads that bolts properly to the stock spindles?  Also if I want to swap my rear drums to disk in the future, do I need a different master cylinder that provides more or less fluid pressure to the rear?
thanks.
John
John
73 Cuda
360 Crate motor
FiTech Fuel injection
727 Trans (wishing it had Over Drive)
Offline TonyBolton
Re: BIG BRAKES
« Reply #1 on: September 03, 2015 - 12:24:08 PM »
I'm sort of in the same boat you are with my 1970. The only kit that I've been seeing out there that is reasonable for the stock disc brake spindles is the one below at Summit Racing.
I'm not really sure why the bigger/nicer kits out there are for the drum spindles?
Re: BIG BRAKES
« Reply #2 on: September 03, 2015 - 01:03:20 PM »
DrDiff  is great to deal with !  http://www.doctordiff.com/brakes/
AR Engineering used to have some stuff too?  http://arengineering.com/
Offline shawge
  • Zoiks!!
Re: BIG BRAKES
« Reply #3 on: September 03, 2015 - 01:27:24 PM »
+1 Dr Diff.  Remember that bigger brakes may require bigger wheels  :2cents:
- Jerry
Offline john h
Re: BIG BRAKES
« Reply #4 on: September 03, 2015 - 01:36:43 PM »
all the kits on That page/site are for stock spindles but they are also 11" rotors.  That's more or less the stock dia. I guess you get better Calipers.    These are Manual disk kits??? Also apparently the 70-72 spindles are different than the 73-74 Ebody???  more confusion......
« Last Edit: September 03, 2015 - 01:39:46 PM by john h »
John
73 Cuda
360 Crate motor
Offline TonyBolton
Re: BIG BRAKES
« Reply #5 on: September 03, 2015 - 01:44:01 PM »
I know....think I'll look into that Dr diff site that was posted.
The diameter of the brake rotor really doesn't determine stopping power it's just the larger heatsink to dissipate.
The caliper is what controls more of the clamping I think the stock calipers are just some random one big piston.... not really that great in my opinion.
Re: BIG BRAKES
« Reply #6 on: September 03, 2015 - 02:00:30 PM »
Good info in here too, especially if your using stock rims (15")
http://www.moparaction.com/Tech/archive/disc-main.html
Re: BIG BRAKES
« Reply #7 on: September 03, 2015 - 02:52:33 PM »
Larger rotors do increase stopping power , the further away from the center of the disc the greater the leverage against the rotor with the same clamping force . you can use the larger Cordoba rotors & the same calipers you have by just swapping the caliper brackets .
 There are other options using drum brake spindles such a Scarebird . DR Diff is great to deal with .
Offline john h
Re: BIG BRAKES
« Reply #8 on: September 04, 2015 - 01:20:56 PM »
thanks for the article. I appreciate the info.
John
73 Cuda
360 Crate motor
