Author Topic: Electrical Problem  (Read 4973 times)
Offline TelisSE440
Re: Electrical Problem
« Reply #15 on: September 06, 2015 - 04:05:22 AM »
Don't rely on grounding the vr with the sheet metal mounting bolt. Make up a ground wire to the motor    :2cents:   Everything on our build has it's own ground wire to battery or block.
That's what happened to me when I installed the new VR, nothing, when I made a ground wire to the motor... It worked excellent
Offline cudabob496
« Reply #16 on: September 10, 2015 - 04:54:07 PM »
Well, replaced the VR, and everything is back to normal. Took
car out and running good. Thanks for the input.
Now back to cruising the town, and street lights, and reminding people
what's a real muscle car!
2011 Kawasaki Z1000
Offline roadman5312
« Reply #17 on: September 10, 2015 - 05:45:31 PM »
                            :2thumbs:   I really like your fresh air system on your avatar pic. Are you picking up the air under the valance aka  Olds 442, or under the bumper in the opening between valance/bumper. ?   Would you mind sharing some pics of the setup. ?  Thanks.   :wave:     :rebel:
Offline cudabob496
« Reply #18 on: September 10, 2015 - 06:04:56 PM »
here's some pics
2011 Kawasaki Z1000
Offline cudabob496
« Reply #19 on: September 10, 2015 - 06:05:59 PM »
one other
« Last Edit: September 10, 2015 - 06:12:42 PM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
« Reply #20 on: September 10, 2015 - 06:08:19 PM »
you figure 1.5% power gain for every 10 degree drop in carb air inlet temp.
so you drop carb air by 50 degrees, then that's 7.5%.
on 500 hp engine, thats 37.5 hp gain.
cheapest hp on the planet!
2011 Kawasaki Z1000
Offline roadman5312
« Reply #21 on: September 10, 2015 - 06:44:16 PM »
                       Very nice set up, thanks for sharing. I've always been a fan of cheap HP gains, and colder air is free  :jumping:. Now if I can just talk Toxicwolf into letting me put some BIG holes in the radiator support.    :woohoo:
        :rebel:
Offline cudabob496
« Reply #22 on: September 10, 2015 - 07:18:43 PM »
        :rebel:
anything for hp!
2011 Kawasaki Z1000
