Author Topic: What Spark Plug to Run?  (Read 1661 times)
Offline Denison636
« on: September 04, 2015 - 02:13:14 AM »
           So I just got news that my motor is done today. It is a 416 with 11.6:1 compression with a little cam. Cam specs are in the pic. The heads casting numbers are in a pic to. The heads are ported and so is my eddy jr intake. 2.02" intake and 1.60" on exhaust. Going to be running E-85 in it on the street. I also have a rev-n-nator box on it with a msd coil and billet distributor. The carb is a 750 that flows over 800 cfm. Also has hooker full length headers with 2-1/2" coming out the side.
            So the question is what spark brand and size should I run with this set up. I know things have changed and would like to know.
Thank you
Its just a little 340 with a miss
Offline cudabob496
Re: What Spark Plug to Run?
« Reply #1 on: September 05, 2015 - 03:04:15 AM »
what kinda heads are they?
2011 Kawasaki Z1000
Offline Denison636
« Reply #2 on: September 06, 2015 - 01:14:43 PM »
The above picture is the only casting number. I think they are mopar performance. But truth be told I am not sure.
Offline cudabob496
« Reply #3 on: September 06, 2015 - 03:00:54 PM »
are they aluminum?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #4 on: September 06, 2015 - 03:27:34 PM »
measure the depth of your threaded spark plug hole
2011 Kawasaki Z1000
Offline cudabob496
« Reply #5 on: September 06, 2015 - 03:45:57 PM »
notice this has a .375 reach, whereas plugs for aluminum
heads have a 3/4 reach, as far as I know. I use NGKs.
http://www.summitracing.com/parts/ngk-3332/overview/make/plymouth/model/cuda
2011 Kawasaki Z1000
Offline Denison636
« Reply #6 on: September 07, 2015 - 01:43:33 AM »
Thank you. I'll get some coming.
Offline Denison636
« Reply #7 on: September 07, 2015 - 01:49:03 AM »
The heads are cast iron and uses all stock hardware. I am still new to the mopar game and still have lots to learn.
