Hi Guys,
I noticed my 'Cuda has starting leaking pretty good around the pan since it has been sitting up for long periods of time while I built my house. I know this is due to the converter emptying back into the pan so I thought, since I don't have my lift in yet, I would take it to a good friend of mine who is a wiz-bang transmission guy who owns his own shop and I trust him.
When I bought the car a year or so ago, I was told the trans had been rebuilt. Upon inspection, we noticed a new tail housing gasket so we know the trans has been opened up but
after dropping the pan, we found a good bid of shinny dots in the pan and on the filter. There were less than a teaspoon amount and non were shavings but all very fine and silver.
The trans shifts out smooth and quite with no signs of issue other than the specs in the pan and the leaking.
We changed the gasket and filter and buttoned it back up while I decide how to proceed. After driving it back home and letting it set in the shop a couple days, it is now leaking worst than ever!
I called my guy and he checked the fluid amount we had originally and found it to be about 3/4 of a quart less than what it should have been. He said this was probably due to my checking the level with the engine warm and the trans in park. Mopars must be checked with the trans in neutral (it says so on the dipstick) but I have a Locar replacement and did not
know this about Mopars. He said it's going to keep leaking so he recommends we rebuild it.
Sorry, for the long drawn out story but would you advice driving it until I realize issues or go ahead and rebuild the tranny?
All advice is appreciated,
Mickm
