Thanks mopar jack for the spec.
I checked the pan bolts and they exceed the 150 in. pounds so If it continues to week, I will be putting in a new gasket.
One additional question. I notice that when I first put the trans in reverse (when the motor is cold) there is a noise which sounds like the pump winning to me, is this normal? This goes away once the car has been driven a bit.
Also, when crusin thur the neighborhood and the speed of motor does not exceed past the shift point into 3rd the trans it will make a hard bump of a noise when it shifts. If your speed is so it shift on thru the point, no noise at all.
Any thoughts?
Thanks,
Mickm
