Author Topic: Crank sprocket Retard/Advance  (Read 2832 times)
Offline mauls
« on: September 06, 2015 - 08:46:11 PM »
I think I know the answer but just wanted to be sure before I put on the timing cover.
I've never had one of these fancy  :lol: crank sprockets.  I don't believe I want any retard or advancement, so I'm just going to set it at 0.  I'm assuming that I put the inner 0 on the key on the crank, and then use the outer 0 to line it up with the crank sprocket?
Thanks
Kansas City, MO
1970 Challenger &2010 Challenger SRT8 six speed
Re: Crank sprocket Retard/Advance
« Reply #1 on: September 06, 2015 - 09:46:23 PM »
correct ....... but if you have the equipment I would degree the cam in as the cam can be ground as much as 11* off in my experience so setting it at zero may not net 0
Offline mauls
« Reply #2 on: September 06, 2015 - 10:28:23 PM »
Thanks for the advice, I do not have a degree kit but a buddy of mine does so i'll try to get his help within the next week.
Kansas City, MO
Offline mauls
« Reply #3 on: September 06, 2015 - 10:31:26 PM »
Another thing i'm curious about is on all the GM motors i've built, the 0 indicator was right on one of the sprocket tips.  This one seems to be in the middle of the tips of some sort so i'm guessing if it lines up right in the middle or on one of the tips.
I'm going to degree it anyways however i was just curious.  I have it installed now just making sure everything fits.  Also I don't plan on running these bolts, I got a set of the ARP bolts on the way.
Kansas City, MO
« Reply #4 on: September 06, 2015 - 10:42:30 PM »
the Keyway position determines where the teeth align , no big deal as long as he dots line up , the tooth position is irrelevant
Offline cudabob496
« Reply #5 on: September 06, 2015 - 11:15:18 PM »
looks like an LS1 motor?
you're good, because if one chain link off, it would be much more out of line.
2011 Kawasaki Z1000
Offline mauls
« Reply #6 on: September 07, 2015 - 12:21:54 AM »
That's my 440
Thanks,
Kansas City, MO
Offline Denison636
« Reply #7 on: September 08, 2015 - 12:11:05 AM »
What kind of chain?
Its just a little 340 with a miss
Offline mauls
« Reply #8 on: September 08, 2015 - 12:21:46 AM »
It's a double roller from summit racing.
I didn't see any kind of thrust plate for the cam, am I missing something?  How does the cam stay put without moving?
Kansas City, MO
« Reply #9 on: September 08, 2015 - 12:51:24 PM »
the oil pump drive puts pressure on the cam pulling it rearward in the block , the timing gear rides on the front face of the block
Offline mauls
« Reply #10 on: September 08, 2015 - 03:01:07 PM »
Alright great!  Just wanted to make sure I wasn't missing anything
Kansas City, MO
