Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Tie Rod sleave question
« previous
next »
Print
Pages: [
1
Author
Topic: Tie Rod sleave question (Read 935 times)
cudabob496
Sr. Resident
on:
September 06, 2015 - 09:04:21 PM »
on my passenger side, the tie rod sleave (between the inner and outer tie rods) is hitting a header pipe, when I turn.
Is there a thinner sleave, or way to modify this, without modifying the header pipe?
Logged
2011 Kawasaki Z1000
Chryco Psycho
Administrator
C-C.com Guru
Re: Tie Rod sleave question
Reply #1 on:
September 06, 2015 - 09:52:27 PM »
sure , use a die grinder & slot the idler arm pivot a little so it sits down lower
Logged
cudabob496
Sr. Resident
Reply #2 on:
September 06, 2015 - 11:57:19 PM »
ok, thanks!
Logged
2011 Kawasaki Z1000
twalker
Full Member
Reply #3 on:
September 07, 2015 - 12:19:01 AM »
I'd like to see before and after pics, can't picture this mod
Sent from my iPad using Tapatalk
Logged
brads70
C-C.com Expert
Reply #4 on:
September 07, 2015 - 08:34:44 AM »
Check your motor mounts? You can also shim your motor mount. But here is a diagram to show what Neil was referring to.
Logged
twalker
Full Member
Reply #5 on:
September 07, 2015 - 08:46:17 AM »
Those diagrams are gold. They just helped me - now I see how I can adjust my power steering pump - was having clearance issues with my left side torsion bar. Thanks a lot Brad
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
