Straight dual exhaust or with H pipe....Sound ?
Author Topic: Straight dual exhaust or with H pipe....Sound ?  (Read 2092 times)
Offline Racer57
« on: September 07, 2015 - 10:35:49 PM »
Which sounds best, I know it performs best.   I don't have an H pipe but would consider it if it sounds better.
Offline ToxicWolf
Re: Straight dual exhaust or with H pipe....Sound ?
« Reply #1 on: September 07, 2015 - 11:51:53 PM »
I have an H pipe that will be going on mine.  From what I've read, the H pipe is louder than the X pipe, but I haven't heard it yet.  :bigsmile:
Offline djw383
« Reply #2 on: September 08, 2015 - 08:21:27 AM »
Straight....much easier to adjust and access the transmission if needed.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3 on: September 08, 2015 - 09:05:14 AM »
TTI makes an H-pipe for a Gear Vendors overdrive if you are thinking about possibly adding on.....
Offline Racer57
« Reply #4 on: September 08, 2015 - 11:24:27 PM »
I have a Tremec TKO500
Offline bennydodge
« Reply #5 on: September 10, 2015 - 01:46:34 PM »
I've had all 3 on my Challenger at different times and I think the no crossover setup sounds best. The x is the strangest sound-a raspy more banshee-like wail at higher revs. Having said that my TTI x pipe is on now because the car is noticeably faster with it. I think having a higher horse engine makes the x pipe shine. Your results may vary....
1973 Dodge Rallye Challenger 340(416 stroker), 727 ,3.23 SG, 76,xxxmi.
2010 Ram 3500 CC Dually 4x4, Cummins, loaded
2015 Challenger R/T classic B5 5.7 8spd
Offline brasil
« Reply #6 on: September 13, 2015 - 01:25:44 PM »
straight.... with HP manifolds.... 2 1/4 tubes....and OEM Mufflers    that´s it.   sounds good...  340 cui with nasty cam.... built to 1970 spec.
Greetings Jurgen
