Author Topic: 340 exhaust bolts proper locations  (Read 2694 times)
Offline culp71
« on: September 08, 2015 - 08:41:05 AM »
ALL,
could someone enlighten me as to which fastener /style goes in what location on a 340 cuda engine for mounting the exhaust manifold?
Offline dakota
Re: 340 exhaust bolts proper locations
« Reply #1 on: September 08, 2015 - 09:17:40 AM »
 :popcorn: just about to put mine back on too.
Offline Rich G
« Reply #2 on: September 08, 2015 - 12:50:08 PM »
I believe the studs go on the two ends and the one with the hex and the stud would go where the pre heater hose shield for the air cleaner if you have one goes. The end holes on the head go through the water jackets
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #3 on: September 08, 2015 - 01:19:46 PM »
Looks like you are missing the sleeve nuts that are used on 340's  :dunno:
This is the 340 kit from Mancini   :2thumbs:
Fits: 1968-70 340 HP
http://www.manciniracing.com/maenexmafaki.html
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline anlauto
« Reply #4 on: September 08, 2015 - 02:50:28 PM »
Yea..he has the 71+ kit.....Studs/nuts on the outer two ends and the bolts only fit in certain holes.
Offline culp71
« Reply #5 on: September 09, 2015 - 08:27:24 AM »
so I should or should not use these sleeve nuts? (which I do have, just missed in pic)
also should the 71 340 shaker cuda use the LH exhaust manifold gasket with spark plug wire heat shield?
(pic attached.)
Offline anlauto
« Reply #6 on: September 09, 2015 - 09:00:48 AM »
Are you working on a 1971 340 ?
Are you using the correct 1971 340 exhaust manifolds ?
If so, then you don't have any sleeve nuts or spark plug heat shields :2cents:
Offline culp71
« Reply #7 on: September 09, 2015 - 12:52:19 PM »
yes, kinda...The engine is a 340 with 71 internals but I used a 70 340 block, as I could not locate 71 block,
and one manifold is actually a 72, (same reason) but was told they were correct style.
so here's my engine, and exhaust manifolds, are they correct for a 71?
so it is going into a 71 cuda, so I want to make it as they were originally.
« Last Edit: September 09, 2015 - 02:18:48 PM by culp71 »
« Reply #8 on: September 09, 2015 - 03:02:21 PM »
if you use those manifolds then you do not need the heat sheild or sleeve nuts , those are used for the 70 upswept manifolds , you would make more power using the magnum manifolds if you are using incorrect ones anyway
Offline anlauto
« Reply #9 on: September 09, 2015 - 03:26:54 PM »
Those are CORRECT 1971 340 manifolds, however the casting date on the one is more likely a 1972 car, same part number.
Using those manifolds as stated DO NOT require sleeve nuts or heat shields.
Offline culp71
« Reply #10 on: September 09, 2015 - 03:39:11 PM »
thank you anlauto, that's what ill do!
Offline dakota
« Reply #11 on: September 29, 2015 - 08:03:34 PM »
The posts above helped me sort out the manifold bolts for my 70 340.   I took a couple of pictures of the manifolds mocked up in case anyone reading this post later might find them helpful (heat shield gasket not installed yet).  The big help was the comment that the hex head bolts go on the ends since they go into the water jacket. The 4 short hex head bolts go on the extreme front and back ends of the manifolds on both sides.   The longer hex heads are on the driver side just inside the shorter hex heads.  The studs take care of the rest with either the sleeve nuts or regular nuts.
