Author Topic: Green Bearings  (Read 2566 times)
Offline lime 70
  • Tires that turn together burn together
Green Bearings
« on: May 26, 2005 - 11:35:27 AM »
 I was thinking about installing a set because my seals are leaking. Anyone try these yet and do think its a good idea :wave:
70 Challenger 440 SIX PACK
Offline Wrencher
  • 73 Plain Jane 318 Auto Project
Re: Green Bearings
« Reply #1 on: May 26, 2005 - 11:38:59 AM »
Forgive me, but what what exactly is "Green Bearings" and how will replacing bearings repair leaking seals?  :dontknow:
Can you clue me in?
Offline Autophile
  • Kowalski... and the keys to a sawed-off weekend!
Re: Green Bearings
« Reply #2 on: May 26, 2005 - 01:54:53 PM »
I am using them on my Cuda. I had to change over from the old adjustable style to these when I installed Wilwood disk brakes. The only real difference is, you would not need to adjust the crown collar thing-a-ma-jig anymore, because the axles would now have a set install depth. There would be no performance gain, or longevity difference, by switching over to the green bearings. If you know how to adjust the old style bearings and are comfortable with them, just stay with them. Note, I had to shorten one of my axles by about 0.200" when I installed green bearings to allow my axles the proper internal clearance. Just a warning to heed if you are thinking about making this change for the heck of it. ;)
Can you clue me in?
Green bearings are also known as snap ring bearings. They use a snap ring to set the depth of how far your axles go into your axle housing. They are not adjustable, which makes it easier and more consistent to install axles. The bearing doesn't do the sealing, it still relies on separate seals to handle leak control.
1971 Cuda, black/black, 419 cu. in. 3G Hemi with twin turbos (build in progress), AlterKtion, Wilwood 12.19" disks, billet Rallye wheels
Offline Wrencher
Re: Green Bearings
« Reply #3 on: May 26, 2005 - 02:03:41 PM »
Okay, I couldn't tell from the original post what bearings lime70 was talking about.  I now realize the post was about rear axle bearings.   :dupe:
It appears from your description that original bearings have an axle endplay adjustment where the "green bearings" do not.
So, does anyone have any idea why they are called "green bearings"?
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Green Bearings
« Reply #4 on: May 26, 2005 - 02:27:25 PM »
green bearing company I believe or sumptin' similar
i found it
Green Ball Bearing Co./Div. of RB&W 9801 Harvard Avenue Cleveland OH 44105
« Last Edit: May 26, 2005 - 08:26:07 PM by OUTLAW »
Offline hemi71
Re: Green Bearings
« Reply #5 on: May 26, 2005 - 04:21:27 PM »
Green bearings are ball bearings, the original Mopar bearings are rollers. the rollers take lateral stresses better than the ball type bearings. Thats the forces the bearings see during turns. That said, for the vast majority of our cars, green bearings are fine. Now if i was going road racing, or driving a lot of miles per year, i'd stick with the rollers. My friend wiped a set of "Green" bearings out in his pickup...at about 40k miles.
Just my .02
Re: Green Bearings
« Reply #6 on: May 27, 2005 - 01:35:18 AM »
if it is just the seals that are leaking & your brgs are OK I would just replace the seals for a LOT less then the cost of the brgs & installation
Offline lime 70
Re: Green Bearings
« Reply #7 on: May 27, 2005 - 06:36:13 PM »
 The seal that I have that leaks is the one on the axle and I am afraid that on along trip that all my bearing grease will run out and the bearing will go dry :eekbig:
Re: Green Bearings
« Reply #8 on: May 28, 2005 - 12:03:58 AM »
in most cases the inner oil seal washes oil thourh the outer seal & the outer seal even if it is worn will keep heavier grease in no problem
Offline kowalski
  • Challenger=SCCA Trans Am Homologation Special
Re: Green Bearings
« Reply #9 on: September 25, 2005 - 10:24:43 PM »
are those green bearings really a crappy road race bearing?
1970 318 bored .060 over edelbrock performer intake ported and polished 360 J heads 2.02 intake 1.60 exhaust double springs carter hi cap fuel pump edelbrock victor series water pump MSD 6AL flotech headers
Re: Green Bearings
« Reply #10 on: September 26, 2005 - 12:12:23 AM »
a ball brg / green brg will not handle the side loads like a tapered roller brg , if you can use the factory tapered brgs it is a better way to go
Offline kowalski
Re: Green Bearings
« Reply #11 on: September 26, 2005 - 10:11:00 AM »
thanks i'll go with the tapered
