Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
1971 cuda Proportioning Valve
« previous
next »
Print
Pages:
1
2
Author
Topic: 1971 cuda Proportioning Valve (Read 4865 times)
EB3-GranCoupe
Sr. Member
BP23 U0B
Re: 1971 cuda Proportioning Valve
Reply #15 on:
September 23, 2015 - 09:31:04 PM »
Sorry, I grabbed the wrong tech manual. Try this one:
http://www.imperialclub.com/Repair/Lit/Master/257/page07.htm
http://www.imperialclub.com/Repair/Lit/Master/257/page08.htm
<--- Check out the diagrams
http://www.imperialclub.com/Repair/Lit/Master/257/page09.htm
Last Edit: September 23, 2015 - 09:38:34 PM by EB3-GranCoupe
Logged
wantone
Full Member
(O O {]{]{]||[}[}[} O O)
Reply #16 on:
September 24, 2015 - 10:39:29 AM »
Ok - so I have 2 sets of info now if you're following where I am coming from. The link to the MBM ((PV6070MOP Mopar Proportioning Valve)) (manufacturer of the dual proportioning valve) tech manual has the outputs listed differently than you spec. I'm a bit freaked out at this point. I have 2 good sources for info and both conflict.
Thanks for your help EB3
Logged
Want one? Got one! ... finally
EB3-GranCoupe
Sr. Member
BP23 U0B
Reply #17 on:
September 24, 2015 - 08:21:15 PM »
Wantone,
I think you don't have to panic just yet. Look at Figure 24, on Page 8 of the Chrysler Tech Manual (my link above). they just show the two valves a little farther apart than the PV6070MOP Mopar Proportioning Valve picture (
http://justpowerbrakes.com/i-7253276-pv6070mop-dodge-plymouth-chrysler-mopar-combination-proportioning-valve.html
). To me they look like the same brass block valves. my guess is that depending on what body they were installed on (A-body, B-body, C-body, E-Body) the spacing of the two valves may have differed.
Matt
Logged
EB3-GranCoupe
Sr. Member
BP23 U0B
Reply #18 on:
September 24, 2015 - 08:25:25 PM »
If you look at Figure 23 on Page 8, you see the proportioning valve has both front and rear fluid going through it. The metering valve is in line with the front brakes, and is basically a delay in actuating the front disc brakes.
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
