Author Topic: Fuel pump for 950 cfm carb  (Read 2132 times)
Offline mauls
« on: September 13, 2015 - 03:03:12 PM »
I've been researching mechanical fuel pump. Motor will be a 512 stroker with a Holley double pumper. I don't mind running a regulator if I have to.
The carter ones look to have too small of a bowl, been looking at the edelbrock ones, any suggestions
Kansas City, MO
1970 Challenger &2010 Challenger SRT8 six speed
Offline cudabob496
Re: Fuel pump for 950 cfm carb
« Reply #1 on: September 13, 2015 - 04:54:57 PM »
a quality mechanical that will give you 6 to 7 psi
make sure at least 3/8 inch inlet and outlet on pump, as flow
rate is just as important as pressure.
2011 Kawasaki Z1000
Offline Denison636
« Reply #2 on: September 16, 2015 - 10:38:49 PM »
What kind of horse power will you be making
Its just a little 340 with a miss
Offline Denison636
« Reply #3 on: September 17, 2015 - 09:41:46 PM »
You want to make sure you have the right size line to. I am going threw this on my build. I am going to switch to electric fuel pump and call it done.
« Reply #4 on: September 17, 2015 - 10:25:36 PM »
Depends on use most mechanical 110 GPH pumpcan keep up for a while but on a long pull more then a 1/4 mile for ex you could go lean , if you want electric the Mallory 110 is awesome & quiet
Offline Plum Crazy 71
« Reply #5 on: September 18, 2015 - 01:33:45 AM »
I'm will be using Aeromotives Phantom fuel pump for my 472 Hemi with 2 - 750 Holleys.
Offline Oldschool
  • Member Since 9-05-06
« Reply #6 on: September 18, 2015 - 10:05:03 AM »
I have been running this pump for years with zero issues in my 528" Hemi pushing 800 HP. This pump feeds 2 - 750 Holley HP's through a regulator set at 6.5 psi.
http://www.summitracing.com/ga/parts/msd-29259
 :thumbsup:
Ken  --  In Georgia
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: September 18, 2015 - 01:21:17 PM »
 :iagree: :iagree: :iagree:
