Author Topic: Door panel hitting strike plate  (Read 926 times)
Offline leanburn
« on: September 13, 2015 - 04:52:36 PM »
 I bought a full interior set of panels, they seem to fit ok but not great. The biggest problem is that they hit the strike plate. It seems that after my car went a full resto the rocker panel seems to be higher. I had to trim 1/2" off my old panels so they would clear. Anyone else encounter this ? I just want to check before I start cutting new panels
Offline CHL2T
  • Handle it, man!
Re: Door panel hitting strike plate
« Reply #1 on: September 14, 2015 - 01:19:30 AM »
If you are talking about the sill plates...... I had to remove the carpet from under them and also give them a mild tweak down to clear the new door panels....
