Author Topic: Master Cylinder, which is correct ???  (Read 628 times)
Offline Lotsapins
« on: September 14, 2015 - 08:14:58 AM »
So the car is a 70 Challenger factory with manual drum brakes. Previous owner has put on 72-74 style spindles calipers and rotors. The brakes work fine, but I don't like the pedal so high and effort used for manual brakes. I'm adding a power booster, but am unsure what master cyl to use. Are they all the same power disc, power drum? Are the fittings the same? I was planning on using a 73 power disc master cyl (10-1515). Am I on the right path? Do I need to mess with proportioning valves. They do work fine right now, I just want power and have a 70-74 booster from another car that I won't be using. Help ???
Thanks , Keith
71 Challenger Conv
Build Thread: http://www.cuda-challenger.com/cc/index.php?topic=97569.0
71' Roadrunner Stock restored 383 4spd
08 Charger SRT8 Super Bee
07 Ram 2500 4WD Cummings
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Master Cylinder, which is correct ???
« Reply #1 on: September 14, 2015 - 08:35:44 AM »
Discs require a different MC.  Call Cass at Dr. Diff to be sure you get the right parts.  http://www.doctordiff.com/
Offline JayBee
« Reply #2 on: September 14, 2015 - 09:01:15 AM »
The Ramman is also an encyclopedia on this stuff.
http://www.theramman.com/
Maybe someone on here can help you first though.
John
1970 Barracuda convertible
2014 Toyota Avalon
