Author Topic: Which swaps in best in a 70 Cuda? 6.1 or 6.4 Hemi?  (Read 5045 times)
Offline Simple
« on: September 14, 2015 - 08:12:12 PM »
Considering a Gen III Hemi in my 70 Cuda. Swapping out tranny as well. Is there any differences in fitting a 6:1 vs a 6.4?
Offline GreenFish
Re: Which swaps in best in a 70 Cuda? 6.1 or 6.4 Hemi?
« Reply #1 on: September 15, 2015 - 11:21:52 AM »
I'm pretty sure its pretty much the same thing. (not that I'm an expert) but if i were in the market, id just buy one of the crate 6.4 engines and put it in.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: September 15, 2015 - 02:33:42 PM »
Dropped in a 6.4 in my friends '73.  Easily fits.
Offline GoodysGotaCuda
« Reply #3 on: September 15, 2015 - 02:54:43 PM »
Packaging is generally the same between the 5.7, 6.1, 6.4.
Primarily comes down to what you want to spend.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Cudakiller70
« Reply #4 on: September 15, 2015 - 04:30:06 PM »
Are their big dollar differences between the engine sizes and what it takes to put them in? Jim
The above is just my opinion
John Adams
« Reply #5 on: September 15, 2015 - 09:59:59 PM »
Install is pretty much synonymous between them, it is primarily a difference in funding the initial power package. You can get a good rebuild-worthy non-Eagle 5.7L for $900-$1,500. With coils, some accessories, fuel rail, intake, etc. A decent mileage 6.1L will run you around $5,000-$6,000, a new 6.4L will push $8,000 for the long block.
My personal path to success is to start with a basic 5.7L. I can easily make ~320whp with it, the initial cost is much lower and will help me actually get "the swap" accomplished. Once I get things settled, the bugs out of it, the transmission setup..then I can work on a larger engine if I please. However, I can also add a small amount of boost to the 5.7L and run a easy 450-500whp without much trouble. However, going from 240whp [318] to around 320whp and from a 904 to a 6-speed manual..I'll be giddy enough to not notice the "lack" in power. The car should be good for an easy 12-second 1/4 with a double-overdrive and net 20mpg or so on the highway.
It's all in what you want to do. Sure, I'd love to have a 6.4L in my car, however I much rather have a 5.7L than nothing..or an old LA small block. Affording a high-end engine right off the bat would push my project budget too far and it would either never get started, or never get finished.
« Last Edit: September 15, 2015 - 10:05:49 PM by GoodysGotaCuda »
1976 Dodge Warlock
« Reply #6 on: September 15, 2015 - 11:48:46 PM »
Ok gotcha, it's the same with GM's LS engines. I am new to mopars, but the newer engines have great torque and run so well. I'm sure with some programming and other changes you can get a lot more power with a lot less headaches plus drivability and more. I am sure you can shred some tires with a 5.7. I am in the same ball park and probably would do the 5.7 it's enough power for me I'm trying to keep this car right side up! Jim
John Adams
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: September 16, 2015 - 05:10:55 PM »
With pic and that statement I see there is no factory K frame there. Will it still clear bottom end with the K and factory steering still there? Engine looks to be dropped down pretty low.
« Last Edit: September 16, 2015 - 05:16:25 PM by YellowThumper »
« Reply #8 on: September 16, 2015 - 06:09:46 PM »
The engine looks relatively at the same place as my picture above, with a stock K-member and Milodon oil pan..
1976 Dodge Warlock
