Author Topic: Toe in  (Read 1861 times)
Toe in
« on: September 14, 2015 - 08:30:00 PM »
Anybody have a good way to measure it at home....by yourself?
Re: Toe in
« Reply #1 on: September 14, 2015 - 08:31:50 PM »
I takes 2 people to do it in my experience
Re: Toe in
« Reply #2 on: September 14, 2015 - 08:37:49 PM »
I use these ...  http://www.jegs.com/i/Allstar-Performance/049/ALL10119/10002/-1?parentProductId=1941624
Works great you can easily do it  by yourself , just pull the tape measures snug.  :2thumbs:
Caster and camber I use this. http://www.longacreracing.com/products.aspx?itemid=1798&prodid=7218&pagetitle=Caster+%2f+Camber+Gauge+w%2f+Magnetic+Adapter
And this adapter if your mounting it directly to the spindle ( with no rotor installed)
 http://www.longacreracing.com/products.aspx?itemid=1799&prodid=7227&pagetitle=Ford+Pinto+Adapter++3%2f4%22+-+16
« Last Edit: September 14, 2015 - 08:46:29 PM by brads70 »
Re: Toe in
« Reply #3 on: September 14, 2015 - 09:29:20 PM »
Re: Toe in
« Reply #4 on: September 19, 2015 - 07:25:32 AM »
That looks pretty cool Brad. How exactly does it attach when you have a wheel mounted? I see they sell it with a magnetic mount but a lot of wheels are alloy/non-magnetic?
Re: Toe in
« Reply #5 on: September 19, 2015 - 04:53:51 PM »
You remove the grease cap on the rotor ( magnetic mount) . Or you can buy the adapter and mount it to the threads on the spindle.
Offline rUNCHARGER
Re: Toe in
« Reply #6 on: September 19, 2015 - 05:09:00 PM »
I just generally measure inside rim to inside rim front and back.
Sheldon
Offline crash340
Re: Toe in
« Reply #7 on: September 19, 2015 - 07:09:24 PM »
I have two pieces of 3/4x1/2" pine about 26" long, one has at each end a builders tape measuer secured to it (the end of the tape with the metal hook), I then use a bungee cord to secure this as high as I can to clear the underside of the car, to one side of the car's outer tire edge on the flat sidewall of the tire.
The other piece of pine is attached to the other side outer tire at teh same height, (use bungee cord through the rim etc) then I simply pass both tape measures und the car and read front and back by hanging the tape measure over the pine. cost me like $15 in materials and very easy to use.
Greg
73 Cuda
Brisbane, Australia
